VPN connection query ...help me
18 years 2 months ago #19880
by blesson
VPN connection query ...help me was created by blesson
Is it possible to set up a VPN connection without using routers and by using the PC(s)...alone ..if yes plz tell me the basic reqirements for the same ...like whether it needs a server and 2 clients and what OS should be use etc......what all the hard ware reqired for the setup and the installation procedure ...
18 years 2 months ago #19883
by Smurf
Replied by Smurf on topic Re: VPN connection query ...help me
Ok, here goes
You can do this with Windows 2003 if you use the RRAS as the VPN Server (although its best if you install ISA Server as this will give you firewalling capabilities also.
I think you can use Windows XP as the VPN Client (pretty sure), this can then connect through to the Windows 2003 server (or better still ISA Server).
This should point ya in the right direction.
18 years 2 months ago #19886
Replied by TheBishop on topic Re: VPN connection query ...help me
Yes you can use the built-in client in XP. If you can, try to use the most basic, simplest arrangement to get started with and then work up to the level of security/complexity you require. I tried jumping straight into the deep end once and it was a bit of a nightmare to configure, specially when using IPSec
18 years 2 months ago #19889
by Smurf
Yes, great advise. Infact, Microsoft have made some enhancement (i beleive) to the PPTP side of things to help further secure it. This may only be in the ISA's implementation though as it does update the RRAS components of Windows 2003.
18 years 2 months ago #19900
by KiLLaBeE
Replied by KiLLaBeE on topic Re: VPN connection query ...help me
After you setup a VPN, how do you KNOW that it truly is setup? Would the way you view the other VPN member be the same as how you would view a local network member, from My Network Places?
K
K
