NAT issue for multiple ports
19 years 7 months ago #19834
by bryantp
NAT issue for multiple ports was created by bryantp
I was just wondreing if anyone had a suggestion for this issue as I can not seem to find an easier way to resolve the issue.
I have two VLAN interfaces on an 871 router.
For one I have a NAT in place.
Now normally when applying a NAT/PAT for a camera system sitting off this device I just put in the port and then allow that port/range in the ACL.
My problem is some devices/applications require a BROAD RANGE of PORTS. Now the ACL can be addressed of course with range. But is there an easier way to keep from typing in each NAT/PAT statement for each port?
I will give an example:
Int FA4 is my outside interface
INT VLAN2 is one of my inside interfaces
I have a static IP of 192.168.200.250 set aside for a server on VLAN2
interface Vlan2
ip address 192.168.200.225 255.255.255.224
ip nat inside
Interface FastEthernet4
ip address xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
ip nat outside
ip access-group 199 in
MY NAT
ip nat inside source static tcp 192.168.200.250 80 interface FastEthernet4 80
ip nat inside source static tcp 192.168.200.250 3550 interface FastEthernet4 3550
ip nat inside source static tcp 192.168.200.250 4550 interface FastEthernet4 4550
ip nat inside source static tcp 192.168.200.250 5550 interface FastEthernet4 5550
access-list 199 permit tcp any eq www any
access-list 199 permit udp any eq domain any
access-list 199 permit tcp any host xxx.xxx.xxx.xxx eq 3550
access-list 199 permit tcp any host xxx.xxx.xxx.xxx eq 4550
access-list 199 permit tcp any host xxx.xxx.xxx.xxx eq 5550
access-list 199 permit tcp any eq 443 any
access-list 199 permit tcp any eq pop3 any
access-list 199 permit tcp any eq smtp any
access-list 199 permit ip xxx.xxx.xxx.xxx 0.0.0.255 any
access-list 199 deny ip any any log
Now you can see that I am allowing anything coming to the PUBLIC IP on ports 3550/4550/5550/80 to be reidrected to my SERVER of 192.168.200.250. And this does work.
The question is how do I get away from MANY STATIC NATS if I have say 130 ports to allow? With the ACL I can just do RANGE but the STATIC NATs would have to be defined individually. Keep I want the same NAT'd addresse(192.168.200.250) to have multiple ports. I have been reading and came across route-map but that looks to use portmap which isn't possible on the 871 model. It could be that I misread the route-map thing. I read several articles today.
Any thoughts or suggestions would be appreciated
Thanks in advance
interface Vlan2
ip nat inside
ip nat outside
MY NAT
Thanks in advance
19 years 7 months ago #19844
by Smurf
Replied by Smurf on topic Re: NAT issue for multiple ports
What you could do is to set up the device as a DMZ device and tell the router to pass everything to it, in affect NAT anything that hits your interface to the internal address. Then you just rely on the Access List to allow the required traffic through.
This can be done by a simply line;
[code:1]ip nat inside source static 192.168.200.250 interface FastEthernet4[/code:1]
19 years 7 months ago #19851
by bryantp
Thanks for the post/reply. However, I do not wish for everything or all traffic to pass to this device. There are 2 VLANs in this box with two seperate LAN NETs. I should have explained this earlier. As such, all traffic can not pass to this (VLAN2) LAN NET.
Replied by bryantp on topic Re: NAT issue for multiple ports
