help with boson simulation
18 years 4 months ago #19218 by Brandonh
For some reason i can not get the serverfarm router to ping the S0 interface on Floor 5's router can anyone tell me what the issue is.
serverfarm's serial 1 interface is connected to the FLoor 5 routers serial 1 interface.
serial farms interface serial 1 is 10.0.0.2/24
Floor 5 router's serial 1 interface is 10.0.0.1/24
Theese routers interfaces are able to ping each other. However Floor 5 has a second interface serial 0 in which serverfarm cannot ping.
I set a route from serverfarm ip route 10.5.0.0 255.255.255.0 10.0.0.1
Floor 5 routers serial interface 0 is 10.5.0.1
So im thinking the route goes from server farm to the 10.0.0.1 "floor 5 routers serial 1 interface then from there it should know to go to its serial 0 interface to the 10.5.0.0 subnet any suggestions ?
18 years 4 months ago #19219 by S0lo
Replied by S0lo on topic Re: help with boson simulation
Can you ping Floor 5 S0 from Floor 5 it self ?
Note that even if the serial 0 is "no shutdown" it has to be connected to be up.
18 years 4 months ago #19227 by Dove
Replied by Dove on topic Re: help with boson simulation
Hi Brandonh,
Can you pls check whether the Floor 5 ROuter's Serial0 interface is UP....?
Dove
18 years 4 months ago #19242 by Brandonh
Replied by Brandonh on topic It works
I finally got it to work i had to connect the first router to the last router then add in all of the routes i believe i intered like 66 routes in all.
