RSA Authentication Manager and RADUIS- Two scenarios
18 years 4 months ago #18972 by zillah
Kindly look at this link below (i know it is oracle) , you can see the Oracle server has got another name which is RADUIS client as well
www.stanford.edu/dept/itss/docs/oracle/1.../b10772/asoradus.htm
Figure 5-1
1- Does the similar concept apply to VPN and RADUIS and SecureID (Token) ?(i.e. VPN is Raduis client )
2- In the diagram below :
www.auckland.ac.nz/security/images/2FAReportv1.pdf
Which one is RADUIS server and Which one is RSA ACE/Server ? My guess is the middle is RADUIS server,,,,Am I right ?.
3- if I have got cisco RADUIS server , do I need to use RSA ACE/Server as well , because RADUIS does support two-way factors Authentication
