Cat 3750 startup problems
18 years 4 months ago #18931
by fpd
Cat 3750 startup problems was created by fpd
Hi Folks,
Looking for assistance with a 3750 that won't start up.
I have included what i get at startup.
Doesn't appear to have startup image, must have been deleted.
System resetting...
Base ethernet MAC Address:
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 2 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 4096
flashfs[0]: Bytes available: 15994880
flashfs[0]: flashfs fsck took 8 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "flash:c3750-i9-mz.121-19.EA1d/c3750-i9-mz.121-19.EA1d.bin"...flash:c375
0-i9-mz.121-19.EA1d/c3750-i9-mz.121-19.EA1d.bin: no such file or directory
Error loading "flash:c3750-i9-mz.121-19.EA1d/c3750-i9-mz.121-19.EA1d.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
switch: dir flash:
Directory of flash:/
2 -rwx 2190 <date> config.text
3 -rwx 24 <date> private-config.text
15994880 bytes available (4096 bytes used)
switch:
System resetting...
done.
image.
switch: dir flash:
switch:
18 years 4 months ago #18934
Replied by TheBishop on topic Re: Cat 3750 startup problems
It certainly looks that way. I'm not in work at the moment but should be able to help you out next week if nobody else has sorted it in the meantime
18 years 4 months ago #18936
by Smurf
Replied by Smurf on topic Re: Cat 3750 startup problems
First of all you will need to download a software image for the switch. If you go
here
(you will need a CCO login) you will be able to select the appropriate image for your license type
Then you will need to boot into ROMMON Mode in order to then TFTP the software off a TFTP server. (pretty sure you should still have ROMMON mode).
I will try and find the guide for you for performing the ROMMON update
18 years 4 months ago #18937
by d_jabsd
you don't have an image installed in flash:
You will need to get into rommon and either netboot it or xmodem an image to it. I would suggest netboot, then you can perform a real image install once its running.
Replied by d_jabsd on topic Re: Cat 3750 startup problems
done.
switch: dir flash:
switch:
18 years 4 months ago #18979
by fpd
Replied by fpd on topic Re: Cat 3750 startup problems
Still having trouble, tried to access the ROMmon mode but unable to, using Termpro and Hyperterminal with all break combinations but with no joy.
18 years 4 months ago #18981
by Smurf
Here
are the different break sequencies for different applications.
At the end of the above document, there is a section "How to Simulate a Break Key Sequence" which may also help ?
Other then that, have you got Cisco SmartNet on the switch ? I would contact Cisco TAC if you have, hopefully they can provide additional steps.
Time to create page: 0.238 seconds
