VPN Solution
18 years 5 months ago #18240 by networknaz
VPN Solution was created by networknaz
Dear All,
Can any one help me in following senario
My Network Setup
Firewall : forti gate
Switch : cisco 2950
Server : AX 400
Connection : ADSL - 512 Kbps
MY need is : i want to accesss AX 400 server from my home
can any one help me in this
solution tried : Port opened in firewall for pptp
rules created in the firewall
now i am not able to access from my home or employees home so please guide in this
Can i go for VPN solution for this
Regards
Naz....
18 years 4 months ago #18253 by Smurf
Replied by Smurf on topic Re: VPN Solution
Hi there,
I am not familiar with your firewall or server however i seem to remember that in order for allowing PPTP you need to not only allow the PPTP Port (TCP 1723) but you also need to enable GRE (Protocol ID 47).
This is the only thing i can suggest because most people don't realise the GRE is also needed for PPTP connection.
Regards
18 years 4 months ago #18256 by networknaz
Replied by networknaz on topic Re: VPN Solution
Thanks but when i open pptp that time GRE also opened so please help me in this issue its very very urgent.
Thanks n Advance
Naz.
18 years 4 months ago #18257 by Smurf
Sorry Naz but I am not familiar with the firewall technology you have. Maybe someone else in this forum has experience in this firewall and will be able to help you out.
18 years 4 months ago #18283 by havohej
Replied by havohej on topic Re: VPN Solution
Hi there,
Regards
hi smurf!
dont know why gre?? I think you need the other side to also set up gre for the tunnel to form, and to work!.
Try vpn remote access solution!. I also never worked with fortynet products, but I think they support it, simple need the vpn client access installed in each machine wishing to acces AX400.
18 years 4 months ago #18292 by DaLight
Replied by DaLight on topic Re: VPN Solution
Are you using the Fortigate as a PPTP server, or are you tunnelling to a PPTP server behind the firewall? This will make a big difference as to how to setup the Fortigate. By the way, the Fortigate will support both modes of operation.
