RJ11 to RJ45
18 years 5 months ago #17916
by Smurf
Aren't the pins in the wrong positions ?
Replied by Smurf on topic Re: RJ11 to RJ45
Try it ... It works ....
18 years 5 months ago #17917
by dchri
RJ45 is the standard used for computer networks. It is also used by many Home Automation devices. RJ11 is the standard used for residential phones lines. RJ11 connectors are smaller than RJ45 jacks and work when plugged into RJ45 jacks. Most RJ11 connectors have only four wires. Most RJ45 connectors have eight wires. RJ11 usually only supports two telephone lines. The most common used wiring standards are: T568A for RJ45 and 6x4 Quad for RJ11. The following is a graphic display of both connectors and how they can be used to work together ...
* RJ45 Pin-Out Specifications * RJ11 Pin-Out Specifications *
* Standard EIA/TIA T568A also called * Standard Residential 6x4 Quad *
* (PANS) Pretty Amazing New Stuff * also called "Burgy", Analog or *
* * (POTS) Plain Old Telephone System *
* * 12345678 * * * 123456 * *
* Pin Colors * Pin Colors Purpose *
* pair/--Tip3 1 White/Green * *
* 3 \--Ring3 2 Green/White * 1 White Not used *
Tip2 3 White/Orange <
> 2 (B)lack Line2 *
* pair/ pair/-Ring1 4 Blue/White <
> 3 (R)ed Line1 *
* 2 \ 1 \-Tip1 5 White/Blue <
> 4 (G)reen Line1 *
Ring2 6 Orange/White <
> 5 (Y)ellow Line2 *
* pair/--Tip4 7 White/Brown * 6 Blue Not used *
* 4 \--Ring4 8 Brown/White * *
"The distance between genius and insanity is measured only by success." --
Replied by dchri on topic Re: RJ11 to RJ45
> 2 (B)lack Line2 *
> 3 (R)ed Line1 *
> 4 (G)reen Line1 *
> 5 (Y)ellow Line2 *
18 years 5 months ago #17920
by Smurf
Well i never, an RJ11 does fit into the RJ45 slot you are quite right
18 years 4 months ago #17993
by Bublitz
The Bublitz
Systems Admin
Replied by Bublitz on topic Re: RJ11 to RJ45
dchri good diagrams. How do people make those cool ASCII drawings...I don't have the patience
The Bublitz
Systems Admin
18 years 4 months ago #17995
by Rockape
Did your system work?
Replied by Rockape on topic Re: RJ11 to RJ45
18 years 4 months ago #17996
by Smurf
Hehe, just tried it in a RJ45 point. It does fit but didn't bother checking the connections as not fully looked into the wireing of the RJ11 cable i was testing with (it was for a modem).
Suppose, if the wireing is the same as UTP then it should do as it fitted snug.
