Cisco 2501 problem
18 years 6 months ago #17379 by jepp
Cisco 2501 problem was created by jepp
I have a cisco 2501 router problem that is troublesome. The router seems to boot up but goes into the a system configuration dialog. It ask me a question if an interface is in use. I try to answer with no but I can't type anything on the terminal. I tried another router with same connection and it works fine, just this router won't let me type anything in. Tried in rmon and still won't let me type anything. Anybody have any ideas about this situation. Here is what boots up on the screen but it won't let me type anything.
System Bootstrap, Version (3.3), SOFTWARE
Copyright (c) 1986-1993 by cisco Systems
2500 processor with 4096 Kbytes of main memory
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
1525 O'Brien Drive
Menlo Park, California 94025
3000 Software (IGS-RXBOOT Bootstrap), Version 9.14(4) fc3, RELEASE SOFTWARE
Copyright (c) 1986-1993 by cisco Systems, Inc.
Compiled Mon 13-Dec-93 15:53 by chansen
cisco 3000 (68030) processor (revision A) with 4096K/2048K bytes of memory.
Processor board serial number 01090035
DDN X.25 software, Version 2.0, NET2 and BFE compliant.
1 Ethernet/IEEE 802.3 interface.
2 Serial network interfaces.
32K bytes of non-volatile configuration memory.
4096K bytes of Flash address space sized on CPU board.
--- System Configuration Dialog ---
Refer to the 'Getting Started' Guide for additional help.
Default settings are in square brackets '[]'.
Configuring interface Ethernet0:
Is this interface in use? [yes]:
Any ideas will be appreciated. I'm new to this field. :?:
18 years 6 months ago #17407 by Dove
Replied by Dove on topic Re: Cisco 2501 problem
hope its boot sequence may bypassed from NVRAM. Pleas be ensure that your boot registry is 0x2102 otherwise try the following command in ROMMON mode
config-register 0x2102
if the registry is ok then be ensure that if the router having the bootup configuration
Dove
18 years 6 months ago #17414 by jepp
Replied by jepp on topic Re: Cisco 2501 problem
When I try to go into rommon it still doesn't let me type anything. I get the rommon prompt and I tried to change the config-registry but with no success because it won't let me type anything on the terminal.
18 years 6 months ago #17543 by Gosbollen
Replied by Gosbollen on topic Re: Cisco 2501 problem
Don't know if this will work, since you can enter the key sequence for RomMon but it's worth a shot. Try one at a time:
1. Use the AUX-port.
2. Change com-port on your computer.
3. Change the rollover cable.
Good luck
18 years 6 months ago #17564 by Dove
Yep, as Gosbollen said, make sure that you are using the appropriate cable to connect you PC with the router. It could be the reason.
Dove
