504 Gateway Unreachable server ...PLEASE HELP
20 years 11 months ago #3427 by sahirh
As Chris said Microsoft firewalls out ICMP messages as well as traceroute so that people cannot map their network.
It is interesting that you get a 'destination net unreachable'. I usually get this
C:\WINDOWS>ping www.microsoft.com
Pinging www2.microsoft.akadns.net [207.46.156.188] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 207.46.156.188:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
20 years 11 months ago #3428 by ice
Hi.
Thanks for the replies :)
I have allowed ALL the ICMP traffic ( not only the replies ) to come
through ( ofcourse only for this moment ) but I still get the same reply even from google :(
I used some scanner to ping www.microsoft.com and the result was that 3/5 ( or if used 3 requests , 2/3 ) pings were successfull but on traceroute I received 'Destination net unreachable' !!!
I even stopped the firewall but still no succes.
google and some other sitees were the same too ( well i even tried your own site but no success ;) )
Any idea?
PS : I'm still able to browse the internet.
20 years 11 months ago #3434 by sahirh
Some ISP's block ICMP.. i don't know why.. but I know that the provider we use at work doesnt allow echo replies.. its really irritating, I can't ping my home machine to see if its up or not.
20 years 1 month ago #7644 by VIJAYKUMARV
Hai Dmix,
I read your problem. Are you solved that problem. Are you checked your proxy server settings in your system. It is located in Tolls, Internet options, connections, LAN settings. I think it will solve your problem.
18 years 8 months ago #15754 by DjTakata
I'm also having problems with a Gateway.
Background details: I got a router, no firewalls.
I have the internet connection, everything works great. No proxies are set, nothing is blocked. Ever since 2 weeks ago I havn't been able to get to www.tibia.com everytime Itry this is what I get:
Gateway Timeout
The following error occurred:
Server unreachable
Please contact the administrator.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Andrew Brunn.ANDREW-97618547>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : ok.shawcable.net
IP Address. . . . . . . . . . . . : 192.168.0.101
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
C:\Documents and Settings\Andrew Brunn.ANDREW-97618547>ping www.tibia.com
Pinging www.tibia.com [62.146.69.27] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 62.146.69.27:
The website is accessible on any other computer except the two in my house...
18 years 8 months ago #15756 by Arani
Replied by Arani on topic issues with pinging
hello ice,
try turning on nslookup and look for all the available servers for microsoft web services. you will be shown a batch of IP addresses for normal services, and for mail etc, try pinging all of them one by one. if all come up with the same destination unreacheable response, then you will have to take it as microsoft block ICMP replies. so even if you have echoes from ICMP enabled from your machine, the same is disabled on the servers at microsoft. apart from that, its not a major issue that you are not able to ping microsoft servers, they are paranoid people on this planet!!!
