Cisco Switch
22 years 10 months ago #1683
by j29net
Cisco Switch was created by j29net
I have a 3550 layer 3 switch with 4 different vlans.
One of the vlans is multicasting its audio/video on the 224.x.x.x
in which all my pcs on that network can recieve audio and video.
th problem is that the multicast is not being forward to the other vlans so no pc on the other vlans get recieve the a/v. I know vlans dont pass multicasts outside of it own vlan...but it can be done.. how do i get the other vlans to get the multicast. Could it be to enable IGMP spoofing..or setting up MVR( which I dont think is the case, because there is no actual physical router involved)
22 years 10 months ago #1684
by sahirh
Replied by sahirh on topic Re: Cisco Switch
Here are a couple of docs that might help you out :
www.cisco.com/univercd/cc/td/doc/product...18a/config/multi.pdf
www.intelligraphics.com/articles/ipmulticasting2_article.html
I haven't done any hardcore research, so if you figure something out then post your results it'll be interesting.
22 years 10 months ago #1695
by j29net
Replied by j29net on topic Re: Cisco Switch
It was neitherof the two options, Look through the "Cisco Routers for IP Routing Little Black Book: The Definitive Guide to Deploying and Configuring Cisco Routers
by Innokenty Rudenko " Nice book by the way.
I found that I need the the commands
(config)#ip multicast-routing {which enables it on that switch}
then on each vlan(interface) in which i wanted to recieve or pass multicasts
(config)#config vlan2
(config-if)#ip pim dense-mode
Worked like a charm.
Since i had a layer 3 switch with ip routing, i could use the router commands on the switch. I also have two switches connected to that switch and am using port trunking so each switch will share its info.
Full IP routing with no router....sweet
