Leased line monitoring tool
18 years 6 months ago #16764 by bvnmani
hi,
I want to monitor my client leased line connection can any one Please suggest good leased line montoring tools..It will be more help for my job....
Thanks & Regards,
bvnmani
18 years 6 months ago #16767 by talk2sp
Replied by talk2sp on topic GFI SOFTWARES...
man try checking out www.gfi.com u may find some kool softwares to use there.
BORN TO BE GREAT
c0de - 3
18 years 6 months ago #16786 by ospf
you may try solarwinds .. very poweerfull NMS ...
www.solarwinds.net
or PRTG www.paessler.com
i tried both already and its very usefull
18 years 6 months ago #16787 by Smurf
I have also used Cacti which is a similar tool to PRTG but you can do loads more monitoring with Cisco switches, routers, firewalls and Microsoft OS's, etc..
www.cacti.net
18 years 6 months ago #16811 by Elohim
The cheapest way is to SNMP monitor the interface that the leased line is connected to. Othewise you will need some very expensive tools. Any SNMP based tool will do it for you.
hi,
Thanks & Regards,
bvnmani
18 years 6 months ago #16815 by Smurf
Yup, Cacti will do this for ya, it also has loads of scripts that people have wrote to work with it :)
