help please i cant ping my other router
18 years 7 months ago #16578
by deepblue
help please i cant ping my other router was created by deepblue
I have 2 cisco 2610 routers connected with a DCE/DTE serial cable
(DCE is connected to router 1)
but i cant ping one from the other can someone please help me
below is the IP route, IP interface, CDP neighbors
and running config from both my routers.
Router 1
Router1>en
Router1#sho ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, * - candidate default
U - per-user static route, o - ODR
Gateway of last resort is not set
172.16.0.0/24 is subnetted, 2 subnets
C 172.16.12.0 is directly connected, Ethernet0/0
C 172.16.10.0 is directly connected, Serial0/0
Router1#sho ip int
Ethernet0/0 is up, line protocol is up
Internet address is 172.16.12.1/24
Broadcast address is 255.255.255.255
Address determined by setup command
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP Fast switching turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Probe proxy name replies are disabled
Policy routing is disabled
Network address translation is disabled
Web Cache Redirect is disabled
BGP Policy Mapping is disabled
Serial0/0 is up, line protocol is up
Internet address is 172.16.10.1/24
MTU is 1500 bytes
IP fast switching on the same interface is enabled
IP multicast fast switching is disabled
Router1# sho cdp ne
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater
Device ID Local Intrfce Holdtme Capability Platform Port ID
Router2 Ser 0/0 153 R 2610 Ser 0/0
Switch Eth 0/0 139 T S WS-C2924M-Fas 0/24
Router1#sho run
Building configuration...
Current configuration:
version 12.0
service timestamps log uptime
hostname Router1
enable secret 5 $1$xCZ3$j3YMuR9vYZ6gqC1D5Q4C51
ip subnet-zero
interface Ethernet0/0
description Lan network on router 1
ip address 172.16.12.1 255.255.255.0
no ip directed-broadcast
interface Serial0/0
description Network connection to router 2
ip address 172.16.10.1 255.255.255.0
no ip mroute-cache
no fair-queue
clockrate 500000
ip classless
line con 0
transport input none
line aux 0
line vty 0 4
password
login
end
Router1#
Router 2
Router2#
Router2#sho ip route
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
C 172.16.11.0 is directly connected, Ethernet0/0
Router2#sho ip int
Internet address is 172.16.11.1/24
MTU is 1500 bytes
WCCP Redirect outbound is disabled
WCCP Redirect inbound is disabled
WCCP Redirect exclude is disabled
Internet address is 172.16.10.2/24
MTU is 1500 bytes
Router2#sho cdp ne
Router1 Ser 0/0 152 R 2610 Ser 0/0
Router2#sho run
Current configuration : 546 bytes
version 12.2
hostname Router2
enable secret 5 $1$vI8.$AAFbc9BOb1kjvIKbgvPMS0
ip subnet-zero
description Lan network for router 2
ip address 172.16.11.1 255.255.255.0
half-duplex
interface Serial0/0
description network connection to router 1
ip address 172.16.10.2 255.255.255.0
ip classless
ip http server
ip pim bidir-enable
line con 0
line aux 0
line vty 0 4
password
login
end
Router2#ping 172.16.12.1Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 172.16.12.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router2#
Router 1
Router1>en
Router1#sho ip int
MTU is 1500 bytes
MTU is 1500 bytes
Router1# sho cdp ne
Router1#sho run
version 12.0
hostname Router1
ip subnet-zero
interface Serial0/0
no ip mroute-cache
no fair-queue
clockrate 500000
ip classless
line con 0
line aux 0
line vty 0 4
password
login
end
Router1#
Router 2
Router2#
Router2#sho ip int
MTU is 1500 bytes
MTU is 1500 bytes
Router2#sho cdp ne
Router2#sho run
version 12.2
hostname Router2
ip subnet-zero
half-duplex
interface Serial0/0
ip classless
ip http server
ip pim bidir-enable
line con 0
line aux 0
line vty 0 4
password
login
end
Router2#
18 years 7 months ago #16585
by ospf
Replied by ospf on topic Re: help please i cant ping my other router
maybe u can try change yr e0/0 at router 2 ip address to 172.16.12.2
18 years 7 months ago #16588
by d_jabsd
Replied by d_jabsd on topic Re: help please i cant ping my other router
You aren't running any sort of routing protocol and you haven't specified any static routes. This means only router 1 will know about 172.16.12.0/24 and only router 2 will know about 172.16.11.0/24.
They will each know about 172.16.10.0/24 network since they are connected. You should be able to ping each side of the .10 /24 right?
add the following:
on r1:
ip route 172.16.11.0 255.255.255.0 172.16.10.2
or r2:
ip route 172.16.12.0 255.255.255.0 172.16.10.1
add the following:
on r1:
or r2:
18 years 7 months ago #16589
by deepblue
Replied by deepblue on topic Re: help please i cant ping my other router
yea each router can ping the other routers serial ".10"
but neather one can ping the others ethernet ".12 and .11"
Im following a lab and it says i should be able to ping the ethernet of the other router.
I added the ip route and it works
now i just have to figure out what I just did
18 years 5 months ago #17369
by ramz77
ram
MCP,MCSA,MCSA MESSAGING, MSCE, CCNA & ITIL
Replied by ramz77 on topic Re: help please i cant ping my other router
You u should check clock rate on the router which is connected with DCE it should be 64000
ram
