WHAT DID I DO WRONG...... DHCP
18 years 7 months ago #16543 by talk2sp
I AM RUNNING A DHCP SERVER WHICH OTHER CLIENTS CONNECT TO IT TO GAIN INTERNET CONNECTION. BUT ALL MY SYSTEMS WERE ASSIGNED IP ADDRESSES AUTOMATICALLY.... BUT THERE IS THIS PARTICULAR SYSTEM THAT HAS REFUSED TO CONNECT I HAVE SHUT DOWN FIREWALL BUT IT STILL HAS NOT CONNECTED....... WHAT DO I DO..... OR COULD IT BE THE NETWORK CARD.... COS ON MY OTHER SYSTEMS WHEN I FINISHED INSTALLING OS (XP SP1) IT STARTED BROWSING AUTOMATICALLY..........
WHAT DO I DO....
THANKS
N.B
(I AM USING A CLIENT / SERVER CONNECTION)
BORN TO BE GREAT
c0de - 3
18 years 7 months ago #16546 by Arani
Replied by Arani on topic IP
please dont repeat your question in different forums. you have already been asked to check the IP address this machine has when it does not connect. check the health of the network card as well.
this is your correct forum. the one in basic concepts is a bit misplaced
18 years 7 months ago #16550 by talk2sp
I THINK ITS MORE OF THE CARD......
BORN TO BE GREAT
c0de - 3
18 years 7 months ago #16551 by sose
windows is not a reliable network operating system for server, and dhcp is is highly unreliable . if you are using 10-15 systems or less, you can configure a linux box as a gateway and assign ip address statically on the clients.
Sose
Bsc Economics, ccna
18 years 7 months ago #16553 by Arani
Replied by Arani on topic Card
if you think it's the card, then try chaning it to see for any difference in performance.
and i would actually agree with sose's point
18 years 7 months ago #16595 by Dove
make sure that the TCP/IP Stack / Loopback by pinging 127.0.0.1 if its works then no problem in your NIC Card. If any problem on this then try to reinstall the N/W Card Driver and make sure that Obtain IP address Automatically and Obtain DNS IP automatically .
Also chk that the DHCP servers are having enough IP address in its pool to lease.
Now chk client machine whether its getting IP r not.
Hope it will help you.
Dove
