Need info. on CISCO terminal server
18 years 6 months ago #17187 by Elohim
If you want to use the 2600 series... get a 2611XM and get a NM-16A network module. The default configuration for the network module already does terminal services. The OCTAL-8 cable all already does roll over.
Hi Dove,
Thanks for your reply.
I am little bit confused!!!!! :roll:
The scenario is like this:
I have leased line between HO and Branch office, which is on 7200 router. I want console of my one switch which is in Branch office form my HO, I want to install Terminal server using router 2600 in Branch office. How can I do this?
In your given configuration you only configured Ethernet and VTY!!
As per my conclusion Ethernet is configured to give IP to the terminal server and VTY is configured to access terminal server via telnet. Is this true!!!!!!!!! :o
