Problem on School project
18 years 7 months ago #16431 by joeyboi
hi guys i'm jus a student having problem problem on my project,i should have done a power point on the case given but i jus had no idea on how to go about......help needed...
Case are as follow....
Case: Point 1- You had been deploy by your company
to solve a network address problem.
Point 2-XYZ Company has 3 networks in 3
different buildings, all connected by
a 64kbps ISDN link.
Point 3-Each network has about 25 nodes on
it, and its own set of servers and
printers for the workers in that
building.
Question: How would you, as a network
Consultant, assign IP addresses
to the building such that,
1-Data would not be broadcast to
every host in the buildings,
causing heavy traffic in the ISDN link
2-Only a single legal IP address is
assigned.
3-The entire network would function
efficiently. .
is my idea on using an extended star topology on the right track??
18 years 7 months ago #16434 by Arani
Replied by Arani on topic network design
considering the point of a "single legal(???) IP" to be assigned, seems there is only one point of internet access. this is where the isdn router resides. i suppose you are thinking of connecting the three buildings with their three seperate seperate networks to this one.
use IP subnetting on the building networks, create three Class C subnets to accomodate all your network nodes i.e nodes, printers, servers etc. this would avoid network traffic bleeding into the other building, and a light sense of privacy as well.
if you are trying to avoid data being not broadcasted to every host under a single network, use switches on the other side of the isdn routers. each building has a switch, hence broadcast storms, or redundant data traffic can be avoided.
18 years 7 months ago #16451 by joeyboi
Thanks alot for your fast reply...it helps alot Thanks again
18 years 7 months ago #16452 by Arani
Replied by Arani on topic how does this look
how is this for a change :D
18 years 7 months ago #16498 by Arani
Replied by Arani on topic pic trouble
joey
can you actually see the picture? because i have just seen it from my office network, and it doesn't show up!!!
maybe its blocking the site from where the picture is being taken from. i upload the pictures on a different site, and link up on other sites as and when needed.
do let me know if anyone can see the network diagram
cheers
18 years 7 months ago #16500 by monsky
hi arani,
i cant see anything.
