Cat5 Patch cable limits
18 years 7 months ago #16353 by Cashless
Can someone tell me if this is a valid LAN connection.
A PC is patched(plugged) to a RJ45 box(box 1)
A patch cable, CAT5 is run from that RJ45 box (1)to another RJ45 box(box 2) 20 feet away. Then a short CAT5 patch cable is run from RJ45 box(2) into a fiber converter.
Will this configuration cause signal problems?
18 years 7 months ago #16367 by jwj
Replied by jwj on topic Re: Cat5 Patch cable limits
More than likely this will not cause any problems. The cable is a short length, and you'll have some small signal losses at the termination points (which is to be expected), I'd expect the greatest hinderance to the signal might occur at the media convertor. However, in my experience I haven't seen a media convertor have much of an effect on signal quality.
-Jeremy-
18 years 7 months ago #16375 by TheBishop
jwj is right, but reading between the lines I wondered why you asked the question. Are you having problems with this installation?
18 years 7 months ago #16428 by Cashless
Thanks for your replies. This set up is new and I wanted to be sure it would not have problems as it serves as a point of sale data connection.
