MAXTNT Downloading speed problem.
18 years 8 months ago #16204
by taqqi14
MAXTNT Downloading speed problem. was created by taqqi14
Hello mates!
I m using MAXTNT as RAS for our ISP clients to connect and browse to the internet..The problem is with ISDN users only.ISDN 128K users connect ok but when they download anything from internet their downloading speed doesnt go beyond 4.5Kbps .As we all know tht for 128K user download speed should go upto ideally 15kbps.Can anyone help us in anyway?
regards
Shahzad Bokhari
Sr.network Engg
regards
Shahzad Bokhari
Sr.network Engg
18 years 7 months ago #16320
by Smurf
Replied by Smurf on topic Re: MAXTNT Downloading speed problem.
Hi there,
I am afraid i know nowthing about MAXTNT, however we did have an issue with our Cisco Routers that were connecting to our central Cisco Routers on ISDN. This was an issue with the routers not raising the second channel.
Just a thought but i'm afraid that is as far as my current expertise can take this. Maybe someone else will have some other thoughts if you have confirmed that both channels are coming up.
18 years 7 months ago #16358
by taqqi14
Replied by taqqi14 on topic Re: MAXTNT Downloading speed problem.
i sort out the prob.Ethernet cable from Maxtnt to switch was creating problems
changed with a new one and problem got solved.
On cisco router "dialer load-threshold" value determines when do u want 2nd channel to come up (as per need basis).Put its value 1 and 2nd channel will instantly comes up with a very small network traffic at BRI interface.
I guess u already wht i m talking about .But if still the problem persists ,u have to check your BRI line voltage ,it must b above 98 volts (100 V is excellent). anything below tht and you'll have channel dropping problems.
Hope it helps
Rgds
Taqqi14
Hope it helps
Rgds
Taqqi14
18 years 7 months ago #16365
by Smurf
Cheers fella, didn't know about the voltage. The problem we had with the Cisco Routers was that it never raised the second channel. The issue was the old version of the IOS we was running which had a bug in it (the IOS hadn't been changed since we bought them in around 1998)
Cheers for the Info
Cheers for the Info
