DNS Entry Cached
18 years 8 months ago #15970 by tfs
DNS Entry Cached was created by tfs
I have a problem with a VPN Client program where address I enter seems to get cached. Using a Windows XP program.
I enter something like:
ping www.fts.com
and get an address of something like:
67.100.12.15.
I then fire up my VPN program which will make my machine look like it is on the local network. At that point, if I type in the same ping statment, I should get something like:
10.0.0.15.
But instead I still get 67.100.12.15.
This only happens when I do the ping before starting my VPN program.
If I reboot the machine, then everything is OK. I assume that www.fts.com with the IP address is cached somewhere.
If this is the case, where would it be and how do I see it and delete it?
Tom
18 years 8 months ago #15972 by FallenZer0
Replied by FallenZer0 on topic Re: DNS Entry Cached
tfs:
Isn't it cached on the Local Machine's DNS Resolver Cache?
ipconfig /displaydns would show you the entries in the Resolver Cache.
ipconfig /flushdns usually clears the entries in the Resolver Cache on the Local Machine.
Pardon me, if my post doesn't answer your question.
FallenZer0
18 years 8 months ago #15983 by d_jabsd
Replied by d_jabsd on topic Re: DNS Entry Cached
In addition to Fallenzero's advice, you can turn off that fucntionality.
Disable the 'DNS Client' service and your system will always query your nameservers, instead of checking the cache first.
As an added bonus, you should see improved network performance.
18 years 8 months ago #15998 by tfs
Replied by tfs on topic Re: DNS Entry Cached
That was the problem.
I also found out when researching the problem that if a DNS has 2 entries for the same server (in my case, mars.fts.com had both 10.0.1.4 and 10.0.2.4) and you had the DNS Client Service off, the DNS would hand out the address in a round robin fashion (10.0.1.4 first then 10.0.2.4 then 10.0.1.4 ...).
This was driving me crazy. I was testing this with 4 machines at home and 3 machines would always get the same address (either 10.0.1.4 or 10.0.2.4). The 4th machine would do the round robin bit.
I finally figure out what was happening.
The 3 machines that always had the same address were XP or W2K Pro machines and the DNS Client was on. When I did a ipconfig /displaydns, I would get the following:
C:\Documents and Settings\ts>ipconfig /displaydns
Windows IP Configuration
1.0.0.127.in-addr.arpa
Record Name . . . . . : 1.0.0.127.in-addr.arpa.
Record Type . . . . . : 12
Time To Live . . . . : 351708
Data Length . . . . . : 4
Section . . . . . . . : Answer
PTR Record . . . . . : localhost
mars.fts.com
Record Name . . . . . : mars.fts.com
Time To Live . . . . : 1195
A (Host) Record . . . : 10.0.1.4
A (Host) Record . . . : 10.0.2.4
As you can see you can see both addresses. If a machine was getting mars.fts.com resolved to 10.0.2.4, the order would be reversed. It apparently always uses the first in the list.
Once you have this in the cache, you would always get the same IP (the first one).
But if you have the DNS Cache off, it will always go to the DNS to get it. And each time the order would reverse.
The reason I only had one machine doing this is that that machine happended to be a W2K Server. I assume the Server has this turned off by default as there really would be no reason to have it on. If I turned it on, it behaved like the workstations did.
I am just curious about the DNS reversing the order of the IPs each time it gets sent out. Is this a normal behavior?
Tom
