Switching Problems
18 years 9 months ago #15436 by teddyshyne
came across this problem today, my switch is not connecting, when i do a show arp it tells me that the interface i am interested in is incomplete. How do i fix this issue, i have tried most level 1 troubleshooting skills...swap cables....reboot router and switch. How do i fix this problem. IS it a Vlan issue cos i have vlan setup on the switch. thots anybody.......Meanwhile i have no internet connection. My thing says limited or no connectivity.....
Thots anyone..... :lol:
18 years 9 months ago #15441 by TheBishop
Replied by TheBishop on topic Switch
Post us the output of the show interface command for the interface in question. Also things rarely stop working for no reason - has anything been changed recently either on the switch or on other devices?
18 years 9 months ago #15444 by teddyshyne
Replied by teddyshyne on topic Re: Switching Problems
nothing has changed.....everything remains the same..
18 years 9 months ago #15487 by The_Berzerker
Replied by The_Berzerker on topic Transfered
I came across this problem today, my switch is not connecting, when i do a show arp it tells me that the interface i am interested in is incomplete. How do i fix this issue, i have tried most level 1 troubleshooting skills...swap cables....reboot router and switch. How do i fix this problem. IS it a Vlan issue cos i have vlan setup on the switch. thots anybody....... 8)
HI,
If u explain little bit more in detail , wht u want to do in a Cisco switch, whoch series of switch u have. By default 1900 and above that seris swicth has VLAN 1 is configured.
Harish
Can you post the output of the show interface command for the interface?
Please do not open duplicate discussions for the same topic, keeping track becomes harder for everyone.
You can continue the discussion on this topic:
www.firewall.cx/modules.php?name=Forums&...iewtopic&p=15444
harish228 please repost your answer on the above topic, since this one will be deleted after a while. Sorry for the trouble!
As nske had noted the discussion has been deleted from the Cisco Lab section...
