regarding cabling extension
18 years 10 months ago #15106
by monsky
regarding cabling extension was created by monsky
hi to all,
because of 100 meters cat5e cable limit, it is a solution to use a repeater or a switch to extend the limit. but how does it affect the network if it is done again let's say 3 times, and is it still could be able to connect workstations on every switch?
e.g. :
90m
16 port switch
90m
24 port switch
PC PC PC
what is the 543 rule?
is the 543 rule applies to this?
any suggestion or link related to this subject:
tnx in advanced
e.g. :
90m
16 port switch
90m
24 port switch
PC PC PC
tnx in advanced
18 years 10 months ago #15108
by Gosbollen
Replied by Gosbollen on topic Re: regarding cabling extension
You only need to worry about the 5-4-3 rule if you use hubs and/or repeaters.
Since you are using switches, you won't have a problem.
More info:
www.webopedia.com/TERM/5/5_4_3_rule.html
/Martin
More info:
/Martin
- The_Berzerker
- Premium Member
18 years 10 months ago #15110
by The_Berzerker
Replied by The_Berzerker on topic Re: regarding cabling extension
The topology that you are suggesting will work without a problem....
18 years 10 months ago #15125
by monsky
Replied by monsky on topic Re: regarding cabling extension
ok thanks to you all for the reply.
i am just thinking for possible problems in the future since i dont know the limits or rules in implementing this.
18 years 10 months ago #15172
Just to close this one off for the benefit of those reading, the 5-4-3 rule as stated defines how much you can extend and Ethernet network using repeaters or hubs. You can have a total of five segments, connected together in a line by four repeaters/hubs, and three of the segments can have active devices (PCs, servers etc) on them. The other two segments have to be point-to-point links used solely to extend the distance. The rule exists to make sure that the collision domain doesn't become too large for the CSMA/CD mechanism to operate effectively
18 years 10 months ago #15194
by monsky
That made the point clear
