Cisco 3500 XL without post
20 years 6 months ago #14576 by pamf
Hello everybody. I'm very happy finding this Site.
I'm a systems technician with a great problem with a Cisco 3500 XL.
The switch received a mains overvoltage and the power supply's primary condenser burned....
I repaired it and check that the 5 and 12 volts in the secondary were OK, but when i connected to the cisco 3500 mainboard only ports leds 1 and 2 were lighting. The system does not start and i can not see any activity in system console.
The 3,2 volts supply in the mainboard does not have output. I tried to power it with an external 3,2 volt supply but i have not response..
Any ideas or service manual ?
Thanks.
pamf
20 years 6 months ago #14577 by The_Berzerker
Hey pamf and welcome to the firewall.cx forums.
I believe that this link might be helpful:
www.cisco.com/en/US/products/hw/switches...9186a00801ab946.html
Look into Diagnosing Problems and Troubleshooting
Inform us if you solve the problem or not
20 years 6 months ago #14579 by pamf
Replied by pamf on topic Catalyst 3500 XL
Hello,
At the moment I do not have solution.
It does not appear any type of boot message or additional information by the console.
It is dead !!! :?
Thank You!!
20 years 6 months ago #14591 by The_Berzerker
When you power on the switch, do the POST tests run?
Do you see any status lights lighting and what color are they?
Look at this section of the article I mentioned earlier if it helps:
www.cisco.com/en/US/products/hw/switches...9186a00801ab94b.html
If your switch doesn't pass POST then you better call Cisco Systems for assistance
Keep us updated,
