routing problem
19 years 3 days ago #14326 by BHARATASHARMA
friends
i am facing problem for routing
i hace cisco 1721 router (192.192.100.22) for leased line
and am using 2600 series (192.192.100.21)for isdn pri line for backup
now in my database server when i put ip routing with both gateways it doesn't supports me
plz do not suggest l3 switch
i want my database to ping the target ip from any of either link as my databse keeps on try with primary gateway doesn't switch over to second
19 years 2 days ago #14333 by TheBishop
Replied by TheBishop on topic Routing
Can you tell us what you want the system to do?
19 years 2 days ago #14336 by d_jabsd
Replied by d_jabsd on topic Re: routing problem
Look into HSRP.
You would want to set the 1721 to be the Primary/active router, the 2600 to be standby/secondary. Then set the primary to track the T1 interface. When the T1 is tracked and it drops, HSRP will move the gateway to the secondary router and pass all traffic to that until the primary comes back online.
