- Thank you received: 10
USB cable length
18 years 11 months ago #14303
by Arani
USB cable length was created by Arani
Problem faced by nekkanti:
"hi , i have d-link wirless adapter , i have addded 5 meters extra cable ,it work when fine with company provided 1 meter wire. it fails when i attach the 5m usb cable. it say it looking for usb bt drivers . may i know whats the problem?"
18 years 11 months ago #14304
by Arani
Replied by Arani on topic usb cable length issue
hi nekkanti,
the maximum length allowed on a usb cable to attached an usb device is 5 metres. since you have already reached the upper limit, i think the signal pair attenuation for that length has exceeded proper signal transfer, and the attenuation is beyond 0.76 db. this is failing the device to see the computer or for the computer to see it.
you said it is looking for usb bt drivers. are you talking about your pc which is looking for drivers?
apart from that, the only reason i can think of right now is that you have struck the limit of maximum allowed usb cable length, which is causing you this problem
18 years 11 months ago #14306
by Arani
on second thoughts, that d-link is a wireless adapter, why not use the wireless capability? isn't that the obvious choice? or are there some constraints on your end on not being able to use the wireless capability?
