problem in networking
- jeffreyx0213
21 years 5 months ago #1393
by jeffreyx0213
Which is worse or worst?
problem in networking was created by jeffreyx0213
i have a 14 computer, before it is connected using two 8port HUB works will, but this time i change connection 16port hub. one computer not ok. although network card and cable work will in other computer when i transfer it. and i have a common OS Win2k Professional.
21 years 5 months ago #1398
by sahirh
Replied by sahirh on topic Re: problem in networking
Okay from what I understood, you've shifted to a single 16 port hub and now one machine doesnt network despite the fact that the cable and the NIC work when you transfered them to another machine ? When you transferred them did you still keep the same cable plugged into the same port on the hub ? If so then the problem lies somewhere with the other machine..
Other than that check that you're not plugging the machine into an uplink port or something....
Hope that helps
Hope that helps
Time to create page: 0.174 seconds
