a problem of cisco 3500 switch
21 years 10 months ago #139 by windmen
I use cisco 3500 switch. I know that I can config the duplex and speed of every interface, using the commands as list:
#interface fa 0/1
#speed 100
#duplex full
but I want to know how could I deal with a group of interfaces, like interface 0/1 to 0/12, using one or two commands, instead of operate above twelve times.
does it exist these commands?
You will never walk alone...
From Anfield, Liverpool
21 years 9 months ago #140 by netNewbie
As much as I know, there is no such command. Try interface fa 0/2 ?, you'll see that the only option after that is <cr>. That means that you gotta do it one by one.
However, you can edit a text file (copy & paste), then send it through the hyperterminal, assuming you're using Windoz. If you are not using Windoz, there gotta be something similar to hyperterminal though.
Newbie
21 years 9 months ago #141 by Chris
Windmen,
To the best of my knowledge, this is not possible.
You will need to configure each interface individually [img]images/smiles/icon_sad.gif[/img]
