Cisco871 and ADSL Modem (Bridged) problems
19 years 2 months ago #12894 by sharol
I am having trouble installing my Cisco 871. I have reset to factory default and configured with SDM but once I am connected I cannot even ping my ISP from the outside IP address of the router without 50% packet loss. I do get a negotiated IP address. I get many TCP retransmissions and duplicate ACKs if I try to browse from my PC. It is not possible for me to even completely load google.com unless I wait a really long time, like 15 minutes.
I have tried different crossover cables and the ADSL modem works fine when my Linux box is being used as a firewall router.
I thought maybe the 871 router was bad so I configured it just as a router behind my linux box and I was able to surf the web just fine on my laptop connected to fa0 and out fa4 to the Net. It has something to do with the pppoe and dialer 0 config I guess. Can anyone see a problem with the config?
Current configuration : 5150 bytes
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname c871
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
enable secret <deleted>
username <deleted> privilege 15 secret <deleted>
clock timezone PCTime -8
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
no aaa new-model
ip subnet-zero
no ip source-route
ip cef
ip dhcp excluded-address 10.10.10.1 10.10.10.9
ip dhcp pool sdm-pool1
import all
network 10.10.10.0 255.255.255.0
dns-server 64.118.98.90 64.118.98.89
default-router 10.10.10.1
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
ip tcp synwait-time 10
no ip bootp server
ip domain name home
ip name-server 64.118.98.90
ip name-server 64.118.98.89
ip ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
bridge irb
interface Null0
no ip unreachables
interface FastEthernet0
no ip address
no cdp enable
spanning-tree portfast
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
no ip address
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface FastEthernet4
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dot11Radio0
no ip address
ssid cisco
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
no cdp enable
bridge-group 1
bridge-group 1 spanning-disabled
interface Vlan1
no ip address
bridge-group 1
interface Dialer0
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip inspect SDM_LOW out
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname <deleted>
ppp chap password <deleted>
ppp pap sent-username <deleted> password <deleted>
interface BVI1
ip address 10.10.10.1 255.255.255.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
logging trap debugging
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp host 64.118.98.89 eq domain any
access-list 101 permit udp host 64.118.98.90 eq domain any
access-list 101 deny ip 10.10.10.0 0.0.0.255 any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any log
dialer-list 1 protocol ip permit
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
Thanks ahead of time.
Time to create page: 0.165 seconds
