vlan on 3com 4226t switch
19 years 2 months ago #12821
by kdawood
vlan on 3com 4226t switch was created by kdawood
My 3com switch is 4000 series switch (4226T)
If anyones know how to configure vlan with these 3com switch, please teach me or tell me the related webpage! Thanks.
Thanks in Advance
Kdawood@gmail.com
Thanks in Advance
Kdawood@gmail.com
19 years 2 months ago #12824
by havohej
Replied by havohej on topic Re: vlan on 3com 4226t switch
Hi.
if you have configured vlans in old catalyst switches the ios and the 3com image is very similar, you must select it by menu options.
I have a 3com 4400 superstack 3, and its an easy task.
here I paste the confifuration, Look at the menu options I choose and then create the vlan.
Type "quit" to return to the previous menu or ? for help
(1)
Select menu option (bridge): quit
Menu options:
3Com SuperStack 3 Switch 4400 SE
bridge - Administer bridge-wide parameters
feature - Administer system features
logout - Logout of the Command Line Interface
physicalInterface - Administer physical interfaces
protocol - Administer protocols
security - Administer security
system - Administer system-level functions
trafficManagement - Administer traffic management
Select menu option: bridge
Menu options:
addressDatabase - Administer bridge addresses
broadcastStormCtrl - Enable/disable broadcast storm control
linkAggregation - Administer aggregated links
multicastFilter - Administer multicast filtering
port - Administer bridge ports
resilientLinks - Administer resilient links
spanningTree - Administer spanning tree
summary - Display summary information
vlan - Administer VLANs
Select menu option (bridge): vlan
Menu options:
create - Create a VLAN
delete - Delete a VLAN
detail - Display detailed information
modify - Modify a VLAN
Select menu option (bridge/vlan): create
Select VLAN ID (2-4094)[3]: 15
Enter VLAN Name [VLAN 15]: firewall.cx
Menu options:
Select menu option (bridge/vlan): modify
Menu options:
addPort - Add a port to a VLAN
name - Name a VLAN
removePort - Remove a port from a VLAN
(1)
Select menu option (bridge/vlan/modify): addport
Select VLAN ID (1-2,10,15)[1]: 15
Select bridge ports (AL1-AL4,unit:port...,?): 1:8
Enter tag type (untagged,tagged): tagged
VLAN ID: 15 Name: firewall.cx
Unit Untagged Member Ports Tagged Member Ports
1 none 8
Aggregated Links none none
thats all, hope it helps.
salute :twisted:
(1)
Menu options:
Menu options:
Menu options:
Menu options:
Menu options:
name - Name a VLAN
(1)
1 none 8
salute :twisted:
Time to create page: 0.263 seconds
