help
19 years 3 months ago #12709 by Coolhemz
help was created by Coolhemz
I have 3 systems with static ip address working in a LAN.
System 1 - Has a class A ip address 10.156.10.1
System 2 - Has a class A ip address 10.156.10.2
System 3 - Has a class A ip address 11.157.11.5
Can I add a ip address 11.157.11.0 to have the system on the networked with each other.Lets says that changing the Ip address is ruled out for system 3.
19 years 3 months ago #12714 by DaLight
Replied by DaLight on topic Re: help
In order to enable communication between the two subnets, you will need to use a router. This could take the form of a standalone device or you could add a second NIC to System 3 and give it a static address in the 10.156.10.x range. Doing this may however introduce security risks depending on your setup.
