Cisco Router Connection
21 years 5 months ago #1356
Replied by Chris on topic Re: Cisco Router Connection
Kennd,
In order to avoid confusion and waist time, can you please answer each of the following from my previous question:
I'll be waiting for the results.
Now, I'll need you to provide us with the following information:
1) From the router's console, can you ping the cable modem ?
2) From the router's console, can you ping any host on the internet?
3) Can any host internally ping the router's "public" interface (eth0/0)
4) Can any host internally ping the cable modem's IP address ?
21 years 5 months ago #1361
by kennd
Replied by kennd on topic Cisco router connection
yes
2) From the router's console, can you ping any host on the nternet? No
3) Can any host internally ping the router's "public" interface (eth0/0) Yes
Yes
Thanks , Ken
yes
Yes
Thanks , Ken
21 years 5 months ago #1378
Kennd,
From the information you have provided, I'd be almost certain that your problem is you ADSL modem/connection and not your Cisco router.
Can you tell me if your ADSL modem assigns a real or private IP to your Cisco's public interface ?
21 years 5 months ago #1385
by kennd
The Cable modem assigns a name to the route and also a public
IP address. The unusual thing about the router is that when the
Cable Modem is connected to the Nat Outside Interface E0/0 it
is assigned a name and IP address almost immediately. When the
Modem is connected to a PC it takes in the region of a hour to get
an IP address
When the Cable Modem is connected to the Router I can ping the
DHCP Server also both of the NTL DNS Servers frm the terminal
and also the command line in the PC
an IP address
