How to speedup web server? Pls help!
- oldstudent
19 years 5 months ago #11539
by oldstudent
Never late to begin
How to speedup web server? Pls help! was created by oldstudent
Hi all,
I had set up webserver with Apache 1.3 on my PC. But it's really poor! Although I'm using DSL connection, Its speed is about 7-8kb/s!
My PC: P4-1.5G 512MB RAM (cause I intend to share for a small group).
How can I speedup my server, esspecially upload speed?
Never late to begin
19 years 5 months ago #11541
by Arani
try this site :
www.speedguide.net/downloads.php
has a good collection of softwares for speeding up your internet connection for uploads and stuff
19 years 5 months ago #11563
by DaLight
Replied by DaLight on topic Re: How to speedup web server? Pls help!
Have you tried surfing from a PC in your LAN?
- oldstudent
19 years 5 months ago #11570
by oldstudent
Any suggestion? Thanks!
Never late to begin
Replied by oldstudent on topic Re: How to speedup web server? Pls help!
I had tried surfing from a PC in my LAN ( http://192.168.0.2), my server has responded immediately. I had tested with some video clip, and It's responded as LAN speed.Have you tried surfing from a PC in your LAN?
Never late to begin
19 years 5 months ago #11571
by nske
Replied by nske on topic Re: How to speedup web server? Pls help!
Before you attempt any kind of troobleshooting, you should specify the problem and narrow down the potential causes as much as possible. By testing your server through your internal network, like Dalight suggested, and discovering that it works as it should, you immediately discarded the possibility that this was a misconfiguration or cpu/memory resource problem of the server.
Two other things to check:
- What is the uplink capacity of your adsl connection theoritically and how much better than the 8K/s does it perform in practice?
- Are there any other factors that would result in consuming the uplink bandwidth or overally saturating your Internet link during the issue (like p2p software, malware, etc.)? This applies for all the devices connected to your network.
- oldstudent
19 years 5 months ago #11614
by oldstudent
Never late to begin
Thanks for your clear reply!
As I tested my server in local network, the problem of server has been discarded. I use some good AV programs ( BitDefender & firewall). I also have some experiences in anti virus, spy and malware is not a problem.
Current test result:
Download Speed: 1857 kbps (232.1 KB/sec transfer rate)
Upload Speed: 317 kbps (39.6 KB/sec transfer rate)
Promising upload speed of my ISP: about 500kbps
By posting this thread, I concentrate on configuring upload connection. Are there any tips to speed up it? I'm using this router:
www.sdt.co.kr/menu3-proc/proc-ZIO-html/INB3040SR.htm
Hope you can help me!
Never late to begin
