Zonealarm and Home Networks
19 years 5 months ago #11248 by TheBishop
Replied by TheBishop on topic ZA
Unless you want to change something or implement some special configuration it will be fine
19 years 5 months ago #11249 by Rockape
whew :wink:
19 years 5 months ago #11252 by DaLight
It was a bit strange because it worked fine even with Zonealarm active. The problem came when the computer was inactive for a few hours. Then either the router or the PC had to be restarted to regain connectivity. It would probably have worked OK if the private network had been added to the trusted networks list, but I didn't feel the need to run Zonealarm as there was a hardware firewall in place and he was happy to run without any egress filtering in place.
19 years 5 months ago #11256 by Rockape
Fair enough,
It still sounds like some kind of timeout issue. Or, as you say, adding it to the Trusted list. but, if he is happy, then "let sleeping dogs lie".
19 years 4 months ago #11649 by rickardo
yep,I get exactly the same problem with my home pc.(loose my internet connection)..have to shutdown zonealarm then refresh :!:
