PC Keeps timing out
19 years 5 months ago #11434 by chandak76
Replied by chandak76 on topic Re: PC Keeps timing out
They must be a problem with the network point,Coz I connected another pc to that point,there was also some timing out
19 years 5 months ago #11446 by jhun
Replied by jhun on topic Re: PC Keeps timing out
it might probably be a physical layer problem. check your cables to see if there are "bad" ones that might be causing the time-outs up to the port of the switch or hub where connection is terminated. either it is a bad cable or a malfunctioning port.
