PLZ Help Me
19 years 6 months ago #10286
by admin
PLZ Help Me was created by admin
Hello All
I am working in telecommunication company. I am facing problem in the company. Actually I have a system that shows which IP is using the bandwidth or downloading too much. we have 5 public IP's but the person who is using the DHCP , I cannot determine who is this employee, because the usage for any DHCP will be shown in the system as the usage for the switch.
Is there any software that can detrmine whcih port of the switch is downloading now (switch port number) ? because If I knew which port it is , then I will know who is this person who makes slow performence in the internet.
please I need a help to solve this problem as soon as possible.
19 years 6 months ago #10287
Replied by Chris on topic Re: PLZ Help Me
Ali,
The information you need to extract is easily done, I just hope your referring to a Cisco switch
I used our Cisco Lab's 2950 Catalyst switch to perform this small presentation
Considering you've got a Cisco switch (2900 series and above) and our wanted host is '192.168.0.2' according to your traffic analysis, you can use the following commands to obtain the information you're after:
[code:1]Firewall.cx#ping 192.168.0.2
Sending 5, 100-byte ICMP Echos to 192.168.0.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms[/code:1]
This command will ensure the switch finds the device with the appropriate IP address and save it into its ram.
[code:1]Firewall.cx#show ip arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 192.168.0.2 0 00c0.9fb7.72f4 ARPA Vlan1
Internet 192.168.0.200 - 0008.2199.4100 ARPA Vlan1[/code:1]
This command will reveal the MAC address of the device we are looking for. In this example, IP Address 192.168.0.2 is associated with MAC address 00c0.9fb7.72f4 .
Next, we need to find out which port maps to this MAC address:
[code:1]Firewall.cx#show mac-address-table
Mac Address Table
Vlan Mac Address Type Ports
1 0002.b33c.3268 DYNAMIC Fa0/7
1 0090.d0eb.dfc4 DYNAMIC Fa0/7
1 00a0.c9ab.0e8f DYNAMIC Fa0/7
1 00c0.9fb7.72f4 DYNAMIC Fa0/1
Total Mac Addresses for this criterion: 4[/code:1]
As you can see, we've discovered that our wanted MAC address/Device is connected to Fast Ethernet port No.1 !
If you require further information or help, please do let us know.
Mac Address Table
