its not exactly networking..but
19 years 7 months ago #10254 by rickardo
can anyone of you good fellows tell me why my son cant hear me on webcam..video is fine,and I can hear him,but its a sort of half duplex audio..any comments on this would be appreciated..cheers :wink:
19 years 7 months ago #10258 by jwj
Which program are you using for this? Maybe it's your microphone, is it functioning properly?
-Jeremy-
19 years 7 months ago #10261 by Rockape
I agree with jwj. It sounds as if either your mic isn't working, or some settings need to be changed in the audio control panel.
Is your son using speakers on the computer, or a headset. If it is a headset, make sure both leads are plugged into the PC. If it is speakers, check that the PC audio settings are setup for speakers and not something else.
Let us know how you get on.
19 years 7 months ago #10283 by gangadar1234
u should have full duplex sound card for net telephoney
19 years 7 months ago #10327 by rickardo
thanks for your comments :wink:
19 years 7 months ago #10330 by jwj
Find anything out?
-Jeremy-
