Random Loss of sound driver HELP PLZZ
18 years 4 months ago #18752 by wannafly172
I have encountered a rather funny issue.... I have a completely random loss of sound driver and i reinstall it and it goes and randomly disappears. no sound installed..... i am running win xp media center.
I have found no pattern What so Ever,.....HELP me plz
"Buddha says, "Know your forms of linux: Mandrake, SUSE, Linspire, Xandros, Lycoris, MEPIS, Fedora Core, and Ubuntu""
It is my job to corrupt young people with the contageous, infectious idea of individual freedom
18 years 4 months ago #18769 by DaLight
Is it on-board sound or do you have a PCI sound card?
18 years 4 months ago #18781 by TheBishop
Have you tried turning System Restore off? Right click My Computer and choose Properties then look on the System Restore tab. Turn system restore off, then install your driver, then reboot, then turn system restore on again
18 years 4 months ago #18795 by wannafly172
Its an onboard card in a toshiba laptop.
I'll check the system restore. Im not sure what else to do...i left the comp on and i still lose the sound randomly
18 years 4 months ago #18796 by DaLight
Strange...
Possible things to check:
1. Are your System standby/hibernation settings affecting the sound. I guess this is only an issue if the sound stays off even after a full reboot.
2. Do you you multiple sound output devices which may be conflicting?
Have you got any audio software installed which may have installed some invasive drivers?
3. Failing all of the above and if, as the Bishop suggested, a System restore does not work, it may be a hardware problem
18 years 4 months ago #18797 by TheBishop
I suggested system restore as its function is to repair the guts of Windows automatically and it sometimes steps in to undo changes. Since it's a driver you're having problems with, system restore has to be a suspect
