I need help setting up network with Quagga.
19 years 3 days ago #14111
by SU27chaos
I need help setting up network with Quagga. was created by SU27chaos
Hi, I wanted to connect two computers to my router that I build with Ubuntu Linux and Quagga (Zebra).
This is how it is set up.
Quagga router has two ethernet interface
Ethernet 0 - 47.4.0.1/17
Ethernet 1 - 47.1.0.1/17
PC0
IP address: 47.1.0.2/17
Gateway: 47.1.0.1
PC1
IP address: 47.4.0.2/17
Gateway: 47.4.0.1/17
Ethernet 0 is connected to PC1
Ethernet 1 is connected to PC0
Both PCs can ping the Quagga router but they can't ping each other.
Both PCs also can ping the other intefaces like 47.4.0.1 from PC0 and 47.1.0.1 from PC1.
PC0
Gateway: 47.1.0.1
PC1
19 years 3 days ago #14112
by monsky
Replied by monsky on topic Re: I need help setting up network with Quagga.
check the ip_forwarding of your router. it is a basic of IP. check this
Link
Link
19 years 3 days ago #14116
by SU27chaos
Replied by SU27chaos on topic Re: I need help setting up network with Quagga.
It's off. I tried to enable that on the global config mode. Still it's off.
19 years 3 days ago #14122
by SU27chaos
Nevermind, I got it to work. The settings was on the OS. Thanks.
19 years 3 days ago #14124
by sujo
Replied by sujo on topic Re: I need help setting up network with Quagga.
what settings you have changed on the OS, can u please explain?
19 years 2 days ago #14143
by SU27chaos
It was on /etc/network/options if you use Ubuntu/Debian
I change the IP forward to yes.
rute.2038bug.com/node28.html.gz#SECTION002872000000000000000
