setting up private proxy
13 years 7 months ago #37307
by pedenski
setting up private proxy was created by pedenski
there are restrictions when viewing websites in my office, using online proxy wouldn't work since even the word 'proxy' is blocked which resorted me to make my own proxy server.
i used CC proxy, and while testing it at home, it appears to be working fine..
using my work-pc at office . i went to firefox and changed the proxy settings, which oddly gives me a blank screen when i browse sites. so i went to wireshark to see if my work-PC really sends REQ to my home-pc (proxy server) which turns out. it does.. not sure why firefox wont load the pages.
13 years 7 months ago #37309
by Nevins
Useful Threads
Replied by Nevins on topic Re: setting up private proxy
You will not win this war against a good systems and network admin without paying for your own internet.
The problem you are facing is your searches can get stopped multiple points along the way and moreover you'll likely get fired in the process if you do get though because your admin is likely looking at a snmp trap packet capture output screen.
Problems you likely face:
Sites blocked by host file. (Chances are it's locked.)
DNS site redirect. (Chances are you are locked out of editing)
Browser Proxy redirect. (Can be locked but is browser specific)
Access control lists. (Cannot be changed blocks ip/ports not keywords)
SNMP Trap. (Someone is likely recording your wasted time at work so they don't have a cause to fire you when it fits their needs)
Okay so lets look at this logically. Chances are your getting redirected before it even gets to the internet by your host file, dns settings and browser settings. You can likely get around the browser but adding another browser (if you are not locked out of installing new programs) and you may even be able to change the dns and host settings if not configured properly. Unfortunately for you, you will likely get blocked by the firewall or router containing the ACL and more over you'll get fired when the SNMP records you trying to access it on work time.
A bit off the main subject but when I was doing network monitoring at my last job we didn't necessarily use messing around on the network as cause for firing someone however management would frequently have record of broken policy added to personnel records so that when they wanted to fire someone for something that they couldn't legally put as cause... they would return to the stored records.
Essentially they would work the situation like this:
Person <a> needs to be fired for <b> but <c> laws prohibit firing for that reason so <d> will be the reason we fire them.
Useful Threads
13 years 7 months ago #37321
Replied by TheBishop on topic Re: setting up private proxy
The organisation I support makes all its users sign up to an IT policy when they join. That way you can't even argue that you didn't realise that what you were doing was disciplinary and/or sackable
13 years 7 months ago #37326
by rizin
Replied by rizin on topic Re: setting up private proxy
Very well said Nevin, I heart fully appreciate your suggestions
13 years 6 months ago #37331
by Nevins
Useful Threads
Useful Threads
