Obtaining and Configuring Centralized Computing
17 years 7 months ago #22794 by ardeef
Hello!
I want to have a centralized computing system such that one PC can have 5 monitors and subsequently,can have 5 users that can work simultaneously.
I know some of the hardware requirements but not all, like, it needs network peripherals such as NIC,switch and cable.
Any idea you can share will be appreciated.Thanks.
17 years 7 months ago #22796 by KiLLaBeE
Which of the following solutions are you aiming for:
1. One computer (server) that multiple users (who only have monitors, keyboards, and mice [no computer]) can connect to --- a thin client network solution.
2. One computer (server) that multiple users (who have monitors, keyboards, and mice) can connect to --- a client/server network solution
If the former, then I can't help you (don't have enough knowledge of the topic), but if the latter, I can give you information and ideas.
N
[/u]
17 years 7 months ago #22799 by ardeef
Killabee wrote:
[Which of the following solutions are you aiming for:
2. One computer (server) that multiple users (who have monitors, keyboards, and mice) can connect to --- a client/server network solution ]
Im not sure if "Thin Client Network" is the correct term, but yes, that is what I am aiming for...Several terminals( each terminal have only their own monitor,keyboard and mouse, and NO PC ) connected to a single PC/server.[/quote]
17 years 7 months ago #22800 by ardeef
17 years 7 months ago #22810 by skepticals
I believe that is considered thin client of dumb terminals. You should be able to do this using Citrix Metaframe or Terminal Services I believe.
17 years 7 months ago #22813 by Smurf
Blimey, thats going back around 30 years before PC's where more affordable and the processing was moved off the mainframe to the desktop.......Terminal Services generally still requires a PC, allbeit lower spec'd to boot up and then allow a Terminal Services Client to run.
I must admit, i haven't really played with either of them (true Thin Client or Client/Server).
