Wireless Bridge Connection - 1300 Aironets
19 years 4 months ago #11260
by IP-bod
Wireless Bridge Connection - 1300 Aironets was created by IP-bod
Hiya,
Am setting up a wifi link between main site and a building next to ours. Have decided to do this with 2 x 1300 cisco aironet. Basically got about 30 users in another building (real close though) want to bridge that connection to the main office where all the resources are. So am setting up 2 1300 aironets between site.
According to www.cisco.com/en/US/products/ps5861/prod...9186a008021e5ca.html
You can have a p2p bridge connection but also a workgroup connection as well. It doens't give much details as to the difference. SO am not sure which to use. Can anyone explain this in a bit more in detail. I am not using any wifi users on the network so this should purely be just setting up a wifi bridge connection.
The remote site will have 30 desktops connecting to a switch and then to the 1300 -> wifi -> 1300 -> Local LAN Main network.
If someone can answer that then i'll proceed with the other issues I'm having with this
Thanks a lot
IP-bod
Thanks a lot
IP-bod
19 years 4 months ago #11264
by tiamat
Replied by tiamat on topic Re: Wireless Bridge Connection - 1300 Aironets
The access point/bridge can be configured as a root access point. In this role, it accepts associations from the following devices:
•Wireless clients
•Repeater access points
•Non-root bridges
•Workgroup bridges
According to you, you will not have any wireless hosts, so this is not the mode you want the WAP to be in.
The access point/bridge can be configured as a workgroup bridge. In this role, the access point/bridge has the following functionality:
•Associates to the following devices:
–Root and repeater access points
–Non-root Cisco Aironet 350 Series Bridge (with clients)
•Operates with both VxWorks and 802.11b/g IOS-based access points and bridges
•Accepts only wired clients
•Informs its root parent of all attached wired clients using IAPP messaging
I would guess this is more like what you want. However, at my company, we are using two 1300's in just the configuration you've described (just to connect two buildings wirelessly - no wifi clients) and we have selected neither of these options on our WAPs. If you'd like, I can send you the config of our WAPs to see how we've done it (mind you, it's not necessarily the right way - we do alot of screwed up things here).
•Wireless clients
•Non-root bridges
•Workgroup bridges
19 years 4 months ago #11277
by IP-bod
Replied by IP-bod on topic Re: Wireless Bridge Connection - 1300 Aironets
Thanks for the response Tiamat. Yep look forward to that info. This has got me scrathing my head a bit now.
IP-bod.
IP-bod.
19 years 4 months ago #11282
by tiamat
the more I look at our own config, it seems to me that we just have one setup as a Root-AP, and the other isn't. There are no clients authenticating with the AP's though, probably because we haven't given out the SSID or Wep key information. Also note things like the open authentication (not a good idea). So with that in mind, take these configs with a grain of salt but I hope they point you in the right direction.
config for wap1 (near end):
[code:1]version 12.3
no service pad
service password-encryption
hostname wap1
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.
username admin privilege 15 password xxxxxxxxxxxxxx
clock timezone R -5
ip subnet-zero
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx transmit-key
encryption mode wep mandatory
ssid xxxxxx
authentication open
infrastructure-ssid
short-slot-time
cca 61
distance 2
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
rts threshold 4000
power local cck 10
power local ofdm 10
power client 1
channel 2462
station-role root
antenna receive right
antenna transmit right
antenna gain 128
infrastructure-client
bridge-group 1
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.0.6.75 255.255.255.248
no ip route-cache
ip default-gateway 10.0.6.73
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging snmp-trap emergencies
logging snmp-trap alerts
logging snmp-trap critical
logging snmp-trap errors
logging snmp-trap warnings
snmp-server community xxxxxxxxx RO
snmp-server community xxxxxxxxxx RW
snmp-server enable traps tty
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
bridge 1 route ip
line con 0
transport preferred all
transport output all
line vty 0 4
transport input all
line vty 5 15
transport input all
end
no service pad
hostname wap1
clock timezone R -5
ip subnet-zero
aaa new-model
bridge irb
no ip address
no ip route-cache
ssid xxxxxx
authentication open
infrastructure-ssid
short-slot-time
cca 61
distance 2
rts threshold 4000
power local cck 10
power local ofdm 10
power client 1
channel 2462
station-role root
antenna gain 128
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
transport input all
line vty 5 15
transport input all
end
19 years 4 months ago #11283
by tiamat
config for wap2 (far end):
version 12.3
no service pad
hostname wap2
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxx.
username admin privilege 15 password xxxxxxxxxxxxxxxxxxxxxxxx
clock timezone R -5
clock summer-time R recurring
ip subnet-zero
aaa new-model
bridge irb
no ip address
no ip route-cache
encryption key 1 size 128bit xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx transmit-key
ssid xxxxxx
authentication open
infrastructure-ssid
short-slot-time
cca 61
rts threshold 4000
power local cck 10
power local ofdm 10
power client 1
station-role non-root
antenna gain 128
bridge-group 1
no ip address
no ip route-cache
speed 100
full-duplex
bridge-group 1
interface BVI1
ip address 10.0.6.76 255.255.255.248
no ip route-cache
ip http server
snmp-server view dot11view ieee802dot11 included
snmp-server community xxxxxxxx RO
bridge 1 route ip
line con 0
line vty 0 4
transport input all
line vty 5 15
transport input all
end
version 12.3
no service pad
hostname wap2
clock timezone R -5
ip subnet-zero
aaa new-model
bridge irb
no ip address
no ip route-cache
ssid xxxxxx
authentication open
infrastructure-ssid
short-slot-time
cca 61
rts threshold 4000
power local cck 10
power local ofdm 10
power client 1
antenna gain 128
bridge-group 1
no ip address
no ip route-cache
speed 100
full-duplex
bridge-group 1
interface BVI1
no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
transport input all
line vty 5 15
transport input all
end
19 years 4 months ago #11669
by IP-bod
I set these 2 up next to each other and get approx 25mb/s max between the 2 bridges and when testing UDP traffic 30 mb/s max when using iperf for both tests. Can someone confirm this is the maximum I will get? ( Seeing that this is .11g 54mbs)
I read a document from Atheros saying this as well???
www.atheros.com/pt/atheros_range_whitepaper.pdf ( pg 3 table 1-1)
Now when i put the 2 between buildings which are approx 15metres apart the max i can get outta the connection is 4mb/s at best
That's almost an 8th of the bw as when they were next to each other!
Am using a 6db antennae that is shipped with these 1300. Is this the cause?? Do i need a higher/better db antennae?
Due to the small distance between them, Direct Line Sight is really not an issue - right?
Have already played around with transmit levels and tried optimzing for range or throughput options as well.
ta
IP-bod
ta
IP-bod
Time to create page: 0.285 seconds
