NIC problem
19 years 9 months ago #8867
by aminos
NIC problem was created by aminos
Hi
I have a weird nic problem : when my pc boots up it tells me that network cable is disconnected and when i unplug it and plug it again the nic works fine and when i do a reboot it becames disconnected.
how to activate it at boot time ?
or should I replace the NIC card, actually i just bought it
I use win2k pro os
Nic manufacture Tamarack
thanks for all.
I use win2k pro os
thanks for all.
19 years 9 months ago #8870
by DaLight
Replied by DaLight on topic Re: NIC problem
Something to check. Does the NIC have LED status lights and are these on when it says the network is disconnected? Since it's a new NIC I wonder if it's a physical connection issue. Just a thought.
19 years 9 months ago #8874
by aminos
Replied by aminos on topic Re: NIC problem
Well actually i have two green leds and they are always on even if it said the network is disconnected
19 years 9 months ago #8875
by nske
Replied by nske on topic Re: NIC problem
Very strange issue
Did you check for latest drivers / windows updates?
Also, your cable is not too long, is it? Check with an other cable anyway in case it is related.
19 years 9 months ago #8876
by DaLight
Really strange.... A couple more questions after trying out nske's suggestions:
1. Is is a fresh install?
2. Have you got any proxy-type software or firewalls running?
