crtl + alt + del
17 years 4 months ago #23984 by tea_clipper
crtl + alt + del was created by tea_clipper
My computer runs windows XP and after freshly installing it,, a few days i try to access the Task Manager but instead prompting me with (The Administrator disabled it). But i am logged on as a administrator how can i enable it..
thank you very much for you help...
Best days!
17 years 4 months ago #23985 by Smurf
Replied by Smurf on topic Re: crtl + alt + del
I would first run some Anti-Virus/Anti-Spyware products to ensure that nothing has got onto it. There's some malware that causes this issue.
Also, is this part of a domain environment ? If so is any group policy set to disable this ?
17 years 4 months ago #23986 by tea_clipper
Replied by tea_clipper on topic Re: crtl + alt + del
this computer is on network of three.....with the same Operating systems windows XP and i just use the sharing thing with no IP address typed on it........
Best days!
17 years 4 months ago #23987 by Smurf
Group policies won't apply in a Peer-to-Peer environment. Its more then likely some malware thats caused this.
If you download some Anti-Spyware software and run some checks on your machine to see if something comes up.
Also, can you run Regedit ? Usually this functionality goes also.
Also,
17 years 4 months ago #23988 by tea_clipper
i cant run regedit at all... can't run the command prompt too.... thank you ....by the way how can i be able to avoid such problems then , and most of this computers are connected to the internet...
Best days!
17 years 4 months ago #23991 by Smurf
I would suggest,
Good Anti-Virus updated regular (if your AV does a kind of on-access scanning, it is best to have it set to on write also which will stop this sort of stuff being written to the hard drive).
Regular scans with AntiSpyware tools
I also quite like SpywareBlaster which can help to stop the infections being hitting your machine in the first place.
I did a thread about AntiSpyware products that i read in a magazine which has some suggestions of products.
