So basic, it hurts to ask......
- gatorengineer
19 years 5 months ago #8861
by gatorengineer
So basic, it hurts to ask...... was created by gatorengineer
So today I got my extra computer for free to learn Linux and setup a Firewall. It's been a long day and I'm no where close to done.
First off, my firewall computer has 2 nic cards and I'm running Smoothwall for the firewall. What my problem is, is that I cannot get logged onto the computer to set the parameters more. I should be able to type 192.168.1.1:81 and it will bring up a menu; however, it is not.
I have the one nic card's IP set up to be 192.168.1.1. I first tried connecting my rounter up to it, but was unsure how I should. Should I use a crossover cable or straight cable? Do I connect through the WAN or the Uplink? (I'm using a linksys 4 port router with uplink and I have a cable modem). This didn't work so I took a crossover cable and hooked it up to the nic card, still no luck. I even tried the other card just for fun to make sure I wasn't wrong.
So any ideas as to why this isn't working. This is frustrating me because I've read all the articles that are not in the forum on this page and understand networking very well, but when I put it into practice, it doesn't seem to work.
Also, what I'm shooting for is a system that is identical to the one in the networking section. Cable modem---->Firewall---->Router then it splits into two networks with one for webserver and the other private.
Laslty, I'm about 100% certain I have the Smoothwall setup correctly. I might have issues with connecting to the internet, but I'll save that for later. I want to get this fixed first.
- gatorengineer
19 years 5 months ago #8862
by gatorengineer
Replied by gatorengineer on topic Re: So basic, it hurts to ask......
I was reading some other stuff trying to solve and remembered that I setup Smoothwall with automatic DHCP with the computers. I also tried assigning my own IP's and that didn't work either. It seems to me that I have exhausted all my options so I guest that is why I'm asking here.
19 years 5 months ago #8871
by DaLight
Replied by DaLight on topic Re: So basic, it hurts to ask......
Just to add to what TheBishop said.
Make sure that your PC is connected to the card set to 192.168.1.1 using a normal cable. The router connection is not relevant at this stage as you can't even communicate with the Firewall on the internal interface (192.168.1.1).
Also since we're not sure if the DHCP service is running, you may try assigning your PC a static address in the same range. Also just to check, Smoothwall's default GREEN interface IP is 192.168.0.1. Are you sure you changed it to 192.168.1.1 during setup?
After checking all the above, boot your PC and try to ping the Firewall on 192.168.1.1 or whatever you set it to to establish connectivity.
Let us know how you get on. I personally use the IPCOP firewall distribution which originated from Smoothwall so I can help with any config problems.
- gatorengineer
19 years 5 months ago #8882
by gatorengineer
I did change my green side IP address to 192.168.1.1 and I did this so that my router would be my DHCP for the time of testing. I have since gotten tired of unhooking cables so I changed the green side IP to 192.168.1.1 and I'm still subnetting at 255.255.255.0, so there should be no problems. I did this to prevent conflict with anything else on the network.
Now once I did that I just took a regular cable and connected the green side card to a regular port on the router and I get nothing. I cannot ping it nor connect to it. I'm very certain I am doing things right, but something is not working. Does it sound like a hardware issue?
19 years 5 months ago #8886
by DaLight
Sorry, I made a mistake in my last post. You can't connect your client PC directly to the IPCOP with a normal cable. You connect a hub/switch to the GREEN side and then plug your client PC into the the hub/switch. Or you can use a crossover cable if you want to avoid using a hub/switch.
As for the router, you should definitely be connecting this to the RED side of your firewall.
