ADSL Modem Question
14 years 3 months ago #35974 by Dhillon
ADSL Modem Question was created by Dhillon
What IP address Can Never Be Used as Default Gateway in any ADSL Modem? :roll:
14 years 3 months ago #35987 by rizin
Replied by rizin on topic Re: ADSL Modem Question
Your Question is bit confusing.
A. However as i given to understand you need One ADSL Modem router which do not use default gateway.
B. or You want to know the default gateway of your ADSL Modem, if yes then Your ISP will assign the Default gateway for your ADSL Modem router.
c. shed more details about your query.
14 years 2 months ago #35993 by Dhillon
Replied by Dhillon on topic Re: ADSL Modem Question
Sorry 2 confuse U
I mean 2 say any Class C IP Address i.e 192.168.1.1
Which is the Class C IP Address that can never be used in any ADSL modem as Default Gateway.
14 years 2 months ago #35997 by Rockape
Replied by Rockape on topic Re: ADSL Modem Question
Hi Mate,
Have a look at this and see if it helps:
compnetworking.about.com/od/workingwithi.../getrouteripaddr.htm
Rockape
14 years 2 months ago #35998 by Dhillon
Thx mates for ur reply
Actually Rockape UR lnk state abut the Gateways and LAN nd WAN IPs that our modem use.
But my question is what Class C IP address that cannot be used as Default Gateway in any ADSL modem.
Actually I have found the answer. the answer is 192.168.1.115 is the Class C IP that cannt use as Default Gateway, But Im unable to find why it is not used as Default Gateway.
If anyone find plz post here.
14 years 2 months ago #36001 by rizin
Actually I have found the answer. the answer is 192.168.1.115 is the Class C IP that cannt use as Default Gateway, But Im unable to find why it is not used as Default Gateway. If anyone find plz post here.
Would you mind provide me the details where you had got the information regarding 192.168.1.115 cannot be use as default gateway.
