Router Ping problem
14 years 6 months ago #35457
by Losh
Router Ping problem was created by Losh
Im using a cisco 2801 router to access the internet. Its configured with NAT and is working well. The problem is that i cant ping well known domain names like
www.google.com
or
www.yahoo.com
but i can ping their ip addresses. The ip domain-lookup command is not disabled either.what could be the problem?
- parasjairath
14 years 6 months ago #35459
by parasjairath
Paras Jairath
Always smiling..!!
Replied by parasjairath on topic Re: Router Ping problem
i will today ask my teacher and will post here soon..!!
its a good issue.. means it sounds interesting...
Paras Jairath
Always smiling..!!
14 years 6 months ago #35464
by sose
sose
Network Engineer
Replied by sose on topic Re: Router Ping problem
Try changing your DNS address with a public DNS and then ping again. It is a dns server problem
sose
Network Engineer
14 years 6 months ago #35465
Replied by Chris on topic Re: Router Ping problem
Losh,
I agree with Sose, it must be a DNS issue. I'm assuming you are unable to ping the urls you mentioned from the router's console.
Try adding a few name servers to your router's configuration and also enabling the DNS service.
You'll find all the information you need on our 'Configuring DNS Services for Cisco routers'
www.firewall.cx/tk-cisco-routers-dns.php
Good luck!
Good luck!
14 years 6 months ago #35470
by Losh
Replied by Losh on topic Re: Router Ping problem
Thanx for that. I use my ISPs two dns servers but let me try adding a few public dns servers n see if it works. Any suggestions on which ones i should try?
14 years 6 months ago #35472
You can try Google's DNS servers : 8.8.8.8 and 8.8.4.4.
Let us know of the results.
