100MB Network card sending at 5MB/Sec
16 years 3 months ago #28795 by skepticals
Why does a 100MB network connection only send at 5MB/sec to a network share.
Is there really that much overhead?
16 years 3 months ago #28799 by S0lo
I hope I'm getting ya well.
A FastEthernet port can theoretically do 100Mbps (Mega bits per second) which translates to 100/8 = 12.5MBps (Mega Bytes per second). Usually it's a 35% to 50% utilization with all the overhead. So that 12.5MBps goes down to about 5MBps. So you're getting the normal rate, I get the same too.
Try switching all ports to Full Duplex, it should show some deference.
16 years 3 months ago #28850 by skepticals
Maybe I should pay attention to the units next time :-)
16 years 3 months ago #28853 by S0lo
It can get confusing indeed those capital and small 'b' :)
16 years 3 months ago #28856 by skepticals
Honestly, I know. You would think I would know the difference. B versus b.
16 years 2 months ago #28862 by TheBishop
<shift> is the key...
Time to create page: 0.279 seconds
