Ftp server using no-ip
16 years 2 months ago #27440
by kalale
Ftp server using no-ip was created by kalale
I've got a dsl line and im using a Zyxel IAD P2606 router, i setup a static ip on the pc, instaaled filezilla server and forwarded port 21 on the router, installed noip updater
when i enter ftp://mynoipaddress i get the page can not be displayed
when i enter http://mynoipaddress it opens my router configuration page.
what have am i doing wrong
thans in advance
thans in advance
16 years 2 months ago #27443
Replied by S0lo on topic Re: Ftp server using no-ip
I assume here that your behind NAT. If you can see your router config page by typing http://mynoipaddress from OUTSIDE your network this verifies that DNS/noip resolution is proceeding OK.
For FTP to work, I believe you need more than just forwarding port 21. There are two ways to do it, either "passive mode" or "active mode". I'll describe "passive mode" because I think it's easier.
In passive mode, you need to forward a range of ports (that are used by Filezilla server) in your router. Go to your FileZilla [Server Options] -> [Passive Mode Settings]. Check the [Use custom port range] then type a port range, say: 50000 - 50050. Now, choose the [Retrieve External IP Address from], this will ensure that your external IP is sent to the ftp client. Click [OK]
Go to your router, setup ports 50000 - 50050 to be forwarded to your FileZilla server (Just like you did for port 21). This should be enough to do it.
16 years 2 months ago #27450
by kalale
Replied by kalale on topic Re: Ftp server using no-ip
thx for the help, im now getting to the ftp page and when i click on "Up to higher level directory" it does this
Index of ftp://???.myftp.org/../../../../../../../../
Name Size Last Modified
16 years 2 months ago #27451
Not sure what is it!. But have you setup a shared/root folder for your FTP user in the FileZilla server. Remember, that this folder will be the root you see in the FTP client. You can't see the parent (higher level directory) of the root. So if you want to see the parent, set it as your shared folder in the FileZilla server.
16 years 1 month ago #27461
by KiLLaBeE
Replied by KiLLaBeE on topic Re: Ftp server using no-ip
I'm guessing this "no-ip" application is some kind of dynamic DNS program that updates your DNS name on root servers with your dynamic IP address from your ISP...am I right?
My suggestion is that before you try to access your FTP from the outside, try to access it from within your network (this will confirm the functionality and most of the configuration of FileZilla and the FTP client that you'll be using). After this passes, try to access your FTP from the outside using your external IP address, which I'll assume is dynamically assigned by your ISP (this will allow you to confirm the functionality of your firewall/router's port forwarding along with some of FileZilla's configurations). After that passes, you can then try to access your FTP by DNS name (which will resolve to your IP address...granted enough time has passed for the DNS information to replicate to all root DNS servers).
As S0lo suggested, you'll have to define the shared folder for root FTP access (this will be the folder that users will see after they connect to the FTP), and grant the users appropriate rights to see the contents.
16 years 1 month ago #27464
by kalale
Someone said the problem could be with the router, but before a start blaming the router, i'll take KiLLaBeE advice and try access it on the lan, some litthe things that we forget that might be very helpfull. wiil let you know once i try that
Time to create page: 0.139 seconds
