D-Link, 3COM and manageable switches
18 years 1 month ago #26970
by zarnick
D-Link, 3COM and manageable switches was created by zarnick
Hello, I have some questions about this 3 things (which of course are related)
1st)What's the best manageable 24 port switch, from D-Link or 3COM? I always used D-Link, but only unmanageable switches...
2nd)I'm planing on make the use of a manageable switch to attach some switches in it (unmanageable) so that every computer attached to one switch, can have a different netmask, assigned via DHCP, this is possible to make with a manageable switch right? Here's a little ASCII draw about what I want to make:
[ Manageable Switch ]
[Switch1] [Switch2] [Switch3]
(10.0.0.1/29) (10.0.0.15/28) (10.0.0.32/27)
I'm not going crazy saying that this is possible right? (we currently have a W2k3 server assigning IPs via DHCP, but since we have only one nic going to the UNmanageable switch, all I can do is put all the ips under the same netmask, or assign fixed ips via MAC address)
Thanks a lot (this is kinda urgente).
18 years 1 month ago #26972
Replied by S0lo on topic Re: D-Link, 3COM and manageable switches
Hi zarnick,
If your manageable switch supports VLANs you certianly can assign different masks and network addresses for each unmanageable switch LAN. Thats by defining 3 VLANs in your Man. switch then defining each port connected to each Un-man. switch to be part of one of those VLANs. Offcourse, you need a router connected to your Man. switch to route between the VLANs. (unless your Man. is a layer 3 switch that can do routing)
Still, your problem with the DHCP server will remain since DHCP broadcasts don't get routed across VLANs. You need some thing called a "DHCP agent" on the two other VLAN (the ones that are not connected to the DHCP nic) to enable it to work.
18 years 1 month ago #26973
by Vell
Replied by Vell on topic Re: D-Link, 3COM and manageable switches
solo you are absolutely right!!!
Hi Zarnick,
If DHCP clients and DHCP server are in different network/vlan,
then you need to DHCP relay agent to switch the packets
to the server.
Hi Zarnick,
to the server.
18 years 1 month ago #26974
by zarnick
Replied by zarnick on topic Re: D-Link, 3COM and manageable switches
Thanks guys, I was actually discussing this with some folks over IRC, and we reached out for this solution, please tell me what you think about it
Problem:
I need 4 different LANs attached to the servers, the lans should be firewalled, and each lan has to have it's custom rule, this, spending the least money possible.
What we have:
1 Windows 2003 Server box that's doing DHCP/DNS/AD/Sharing and Internal Firewall
1 Bridge to protect the w2k3 box from the internet and act as a proxy
1 D-Link Unmanageable 24 port switch
The solution we arrived:
Get:
1 Layer 2 Switch that supports VLAN and DHCP Relay
1 4 ethernet port NIC
1 Linux box
Put the 4 port NIC into the linux box, assign 4 different DHCP servers per port of the NIC, and put this Linux box for making the routing (maybe with Zebra?) so that every client can talk to each other (even if they are on different networks), and since we are here we can as well put this as an internal firewall, then the W2K3 box would be left for doing only DNS/AD and sharing, thus leaving it with a lot of less work. Then we would create 4 vlans on the manageable switch, with 2 ports each, one for a new unmanageable switch, and another connecting each vlan to a different dhcp server on the linux box, then set up 4 DHCP Relays, one for each vlan of course.
Do you guys think this might work?
Problem:
What we have:
Get:
1 Linux box
18 years 1 month ago #26975
Wonderfull, Agree on all, except for 2 things, First I don't see why you will need DHCP relay agents any more since you are setting separate DHCP servers for each VLAN. Second, The "1 D-Link Unmanageable 24 port switch" would physically still be connecting all VLANs together, although logically they are separate. Nothing is wrong with that, but if you are VERY concerned with security issues, then that is not the best way to do it. Although your traffic between the VLANs will be flowing through the router (linux box), some hacking software is available that can sniff un-man. switches. In other words, listen to other VLANs on the same un-man. switch.
The perfect solution off course would be to have 4 un-man switches, you can by 8 or 12 port un-man switch cheap. Again, this is just for security issues, not a big deal if you don't care.
By the way, do you really have to separate into subnetworks, you might as well just run 1 VLAN, 1 DHCP, no router, firewall between you and internet, and thats it.
18 years 1 month ago #26977
by zarnick
Unfortunately, yes, I do need to make the different VLANs, I can of course just make different subnetworks if I can get the 4 port NIC, and start with 4 un manageable switches, I would like to have the manageable switch tough, so I can easily implement some QoS between the different VLANs (we have some kind of problem with bandwith, and this could help us a lot saving some bandwith if I'm wright), so I really think I could start with the 4 port nic, 4 un manageable switches and build up from that...what do you guys think?
