routable ip
18 years 2 months ago #20448 by sanju1010
routable ip was created by sanju1010
What is routable ip and what is non-routable ip? How router knows whether the ip which it has to route is routable or non-routable
18 years 2 months ago #20449 by Smurf
Replied by Smurf on topic Re: routable ip
IP is a routed protocol and therefore is routable. It all depends on if Default Gateways and/or Routes are configured to forward the IP Traffic on.
Like i have been saying, its best to look through the articles as a lot of the questions you are asking are covered in them.
18 years 2 months ago #20485 by toddwoo
Replied by toddwoo on topic Re: routable ip
Are you talking about specific routes in a specific network setup...
IE.Can 10.10.0.2 route to 10.0.5.2?
or are you asking about completely non routeable IP... like 127.0.0.1 on a local lan, or how Private IP addresses (like 192.168.0.2) can't be routed to the internet...???
I understand some of it.. and some.. i'm not so clear. But I'm not sure what is being asked.
Todd
18 years 2 months ago #20488 by TheBishop
Replied by TheBishop on topic Re: routable ip
All IP addresses are routable; as long as you have two unicast IP addresses that are on different IP networks (which is where the subnet mask comes in), then you can make a router route between them. (I carefully said 'unicast' because multicasts can be a little different but that's a digression). Having said that, there are a few IP address ranges that are not routable across the intenet - not because those addresses are some how not routable, but because by common agreement it was considered desirable to have some 'private' IP address ranges that you can use internally without fear of them being accessible to the world. If you're using your own private isolated network however you can route between these private addresses without any problem
18 years 2 months ago #20491 by toddwoo
So in reality there is a very small number of "NON-Routable" ip addresses, which are not routeable because the IP or range is reserved? Correct?
And when we say "Non routable" we should be saying "non internet routeable"? And there is no "hard" restriction on this, just a software/protocol level decision to omit routes for them. Is that decision made on each router or is it built into the routing protocol?
IE: BGP won't let you route, specifically or by default a 192.168.0.0 network?
18 years 2 months ago #20492 by TheBishop
That's right. And the non-routable addresses are non-routable because that was the design decision taken when the internet was "invented", see RFC1818: www.rfc-editor.org/rfc/rfc1918.txt . Exactly how the blocking is done I'm not sure - but I'm certain someone out there will shortly tell us...
