DSLAM Basics
18 years 11 months ago #11996 by westwindshelley
DSLAM Basics was created by westwindshelley
What is the concept of DSLAM
What are the things which constitute a DSLAM
How does it work as a multiplexer as what I know about multiplexers is that it has many inputs and one output and that the output is achieved with the help of the combination of switches
How does it functions with a radius server
In God we trust but for everything else we need data
18 years 10 months ago #12510 by Ranger24
Replied by Ranger24 on topic DSLAM concept 0- In brief
DSLAM stands for Digital Subscriber Line Access Multiplixer. It's primary function is to provide broadband connections to subscribers based upon various DSL flavours, e.g.;
ADSL - Asymetrical Digital subscriber Line
VDSL - Very High Speed DSL
SH.DSL - Symetrical High Speed DSL
DSLAMs are split in to 2 sides - Customer Side & Trunk Side.
Customer side is where the customer telephone lines are connected and trunk side is where the dslam connects to the ISP network.
On the customer side each line is configured to supply a data connection via DSL to the customer modem. Customer connections are always ATM over DSL - this means the customers ethernet frames (from their PC) are put in to ATM cells which are transmitted vis the DSL on their phone line to the DSLAM.
The trunk side can use various connections depending upon the make & model. Typically trunk connections are ATM, Ethernet or IP.
Trunk interfaces can include:
- STM1 155mb/s
- DS3 (Americas approx 34 Mb/s)
- E1 (European approx 2 Mb/s)
- Gigabit Ethernet 1000 Mb/s
- Fast Ethernet Mb/s
Depending on the trunk connection the DLSAM can make connections between the customer side and the trunk side in a number of ways:
1) ATM DSLAM
- Customer modem packages ethernet frames in to Atm Cells
- ATM cells are transmitted over the phone line using DSL
- DSLAM line card receives ATM cells and passes them to Control card
- Control card switched ATM cells via switching Fabric to trunk interface
- ATM cells are forwarded via ATM network to BRAS - Broadband Remote Access Server (edge router with radius/ authentication functions)
2) ETHERNET DSLAM
- Control card re-assembles ethernet frame from ATM cells
- Ethernet frames forwarded to VLAN based trunk interface based on connection table and on to BRAS
3) IP DSLAM
- IP Packets are removed from ethernet frames
- IP Packets are routed to VLAN based trunk interface based on routing table and on to BRAS
A typical network would look like this:
PC --> CPE --> DLSAM --(ATM / Ethernet network)-- -->BRAS --> WWW
(CPE = customer premisies equipment, or DSL Modem)
Please feel free to ask further questions, and please let state where you are in the world as the european implementation is different from the Asian implementation which is different from the Americas implementation
- Ranger
18 years 10 months ago #12550 by nske
Replied by nske on topic Re: DSLAM Basics
Great post! It filled me in as well, thanks :)
18 years 10 months ago #12566 by dwyane
Replied by dwyane on topic Re: DSLAM Basics
great post Ranger24, one of the best explanations regarding DSLAM , The only thing i knew earlier was DSLAM seggregates the ISP from the customer
18 years 10 months ago #12586 by DaLight
Replied by DaLight on topic Re: DSLAM Basics
Excellent post Ranger24! All I knew about DSLAMs previously was that they were installed at British Telecom's telephone exchanges for connection to the ISP networks. You've made it so clear.
18 years 10 months ago #12593 by dwyane
Do u have any information on the LP ( low pass ) card and the LT ( line termination) card :?:
Time to create page: 0.141 seconds
