Opening Port Range for Cisco ASA 5505
16 years 2 months ago #29029
by jhun
Opening Port Range for Cisco ASA 5505 was created by jhun
Hi all,
Just wanted to ask on how to open up a range of ports on the cisco asa? I would like to open up UDP ports 10000-20000
I have found a way and the code is below:
access-list outside_access_in extended permit udp any host 'public ip' range 10000 20000
static (inside, outside) interface 'private ip' 'public ip' netmask 255.255.255.255
The above code works find, however the 2nd commnad (static(inside,outside)) gives the warning that:
WARNING: All traffic destined to the IP address of the outside interface is being redirected.
WARNING: Users will not be able to access any service enabled on the outside interface.
Since this is the case, it does not allow me to do ssh remotely on the ASA because all traffic are redirected to the private ip address specified which is a different ip used by the ASA.
Are there other ways of doing this?
Tried google and saw a bunch but none was really working.
I do not want to open up each port individually (which requires opening a thousand of them) to make it work the way I intend it to be.
So any suggestions and/or additional information would be very appreciated.
16 years 2 months ago #29033
by Smurf
Replied by Smurf on topic Re: Opening Port Range for Cisco ASA 5505
The warning is correct, you are redirecting everything received on the external interface (outside) to the internal server. Therefore any services on the Firewall will not work (i.e. SSH, Telnet, SSL, etc...)
The only way around it is if you have multiple Public IP Addresses available to you and then leave the public address thats attached to the external interface and use one of the other free addresses in your public range within the static statement.
Alternataively, you will need to specify the ports.
(the only thing i can think is to setup another static statement and try throwing the traffic fo the single SSH port number back to its internal interface. I have never tried this but it may work ? Unfortunately i dont deal with Cisco kit anymore so i have no way of testing this for you, just thinking out aloud).
I am guessing you need to allow udp ports 10000 - 20000 through for the service you are opening up ? Is there no other way to acheive it ?
16 years 2 months ago #29044
[code:1]ERROR: mapped-address conflict with existing static[/code:1]
I though of defining an access list or object-group to map the 10000 to 20000 range but unfortunately the the static command syntax does not accept that for the global-ip global-port fields.
Replied by S0lo on topic Re: Opening Port Range for Cisco ASA 5505
Exactly whats in my mind too. This would be your easiest bet jhun.The only way around it is if you have multiple Public IP Addresses available to you and then leave the public address thats attached to the external interface and use one of the other free addresses in your public range within the static statement.
Unfortunately did not work when I tried it. It gives the following error:(the only thing i can think is to setup another static statement and try throwing the traffic fo the single SSH port number back to its internal interface. I have never tried this but it may work ? Unfortunately i dont deal with Cisco kit anymore so i have no way of testing this for you, just thinking out aloud).
16 years 2 months ago #29046
by jhun
Replied by jhun on topic Re: Opening Port Range for Cisco ASA 5505
Thank you smurf & solo,
How would i go about in defining this on another public ip address.
I do have additional public ip addresses that i could use. any pointers in the command or an example would be appreciated.
Thanks again.
Thanks again.
16 years 2 months ago #29051
Pretty much the same way you did above with few changes. Remove the "interface" keyword from the static statement and use your additional public IP instead of the outside interface IP in both the access-list and static statements. Like this:
[code:1]access-list outside_access_in extended permit udp any host <public ip> range 10000 20000
static (inside, outside) <public ip> <private ip> netmask 255.255.255.255
access-group outside_access_in in interface outside[/code:1]
Obviously, your outside clients need to access the service using the additional IP.
16 years 1 month ago #29155
by jhun
Thanks SOlo,
The commands worked like a charm.
I tried the commands previously and it did not work the first time.Looking at my config again I've seen that I lacked an additional command which was the global (outside) statement for your outside interface to be able to add the additional public ip
static (inside,outside) <public ip> <private ip> netmask 255.255.255.255
global (outside) 1 <public ip>
Thanks again
Thanks again
